I’m replacing my clutch for the first time and looking for advice!
woodsm84
Current bike(s): Dr650
VRSCA 2003
Voyager XII
Has liked: 22 times
Post by woodsm84 »
If I understand the process correctly, it should go similar to this?
Soak the new plates
Drain oil
Remove case
Remove spring bolts and springs
Pull off pressure plate
Remove old clutch plates (does the plates orientation in the basket matter?)
Add new plates
Add new springs
Replace and rebolt pressure plate
Add new gasket
Bolt cover back on
Billed from the slave cylinder and add new fluid
What steps am I missing?
Has liked: 107 times
Been liked: 277 times
Re: I’m replacing my clutch for the first time and looking for advice!
On a pre 1991 model that is pretty much the way to do it with the following caveat: the last friction plate to be installed has the tangs rotated 1 groove of the housing slots; see service manual Section 5 page 10.
As well the 2 thinner steel plates are the first and the last steel plates installed, the thicker plates being the 2nd through the 7th plates installed.
It gets a little more complicated with 1991 and later plate assemblies as the stack height needs to be measured and the steel plate thickness/es may need adjusting to get to the specified clearances; see service manual "Supplement" section 5 page 4.
Conrad (Tue Nov 15, 2022 1:05 am) • Bonnie and Clyde (Tue Nov 15, 2022 5:33 pm)
Bonnie and Clyde
2007 KTM Super Enduro 950
2019 KTM xcw 300 TPI
Has liked: 189 times
Been liked: 50 times
Post by Bonnie and Clyde »
Tell us what year your bike is. How many miles are on it and why you think the clutch needs changing. Please and thankyou
Unless the plate assembly has been abused it is uncommon for clutch slippage to be due to plate wear, although of course it does occur to some units without being abused.
Generally the small return hole in the master cylinder is not open or it is becoming blocked with corrosion and the line pressure can not be released which results in a disengaged clutch assembly.
Another cause I have seen is the slave cylinder piston can't return into the cylinder bore due to corrosion in the groove behind the internal rubber piston seal. The corrosion forces the rubber seal out tight against the piston thus causing a lack of clearance, normal clearance would allow the piston to move easily in the bore.
A third cause could be a missing or deteriorated slave cylinder spacer, the black plastic 3 hole piece that goes between the slave cylinder and the aluminium bevel gear housing.
Another possible culprit is the pressure plate springs and I find these are usually below the minimum length allowable. But even old tired springs generally don't slip unless the bike is really loaded down in 3rd gear, going uphill, with a sudden roll-on of the throttle and then they might, just might, slip.
And of course as I stated earlier, some units do in fact wear out and need plate replacement, although I suspect more plates have been changed out than were actually needed.
Just my opinion though and I am sure others have had additional causes which can be related.
cushman eagle (Thu Nov 17, 2022 1:41 am) • ekap1200 (Thu Nov 17, 2022 10:10 pm)
woodsm84
VRSCA 2003
Voyager XII
Has liked: 22 times
Post by woodsm84 »
Bonnie and Clyde wrote: Tue Nov 15, 2022 5:35 pm Tell us what year your bike is. How many miles are on it and why you think the clutch needs changing. Please and thankyou
Sorry to take so long getting back. It was slipping beyond drivability. The plates looked terrible. I have no throw on my lever now unfortunately. Gotta find out what I missed
KevinZ
Current bike(s): 1986 Kawasaki Voyager XII (Daisy)
1983 Yamaha Virago 500
Post by KevinZ »
How is your progress coming?
I had my clutch and brake fluid changed in 2021. The tech changed out the levers and master cylinders due to corrosion.
Have you been able to bleed the clutch system with new fluid?
