Motorcycle jack
Conrad
89 yamaha venture royale
Has liked: 25 times
Been liked: 59 times
Motorcycle jack
Post by Conrad »
So i ran across a handful of posts on the forum here about concern over crushing exhaust pipes by lifting the voyager with a standard harbor freight motorcycle jack.
My question is, has anyone actually had this happen, or just being cautious?
I ask because j have used this jack to lift a few big bikes, specifically my yamaha venture, where the pipes run under the frame and it's basically resting on the pipes, with no problem whatsoever, and I'm wondering if the voyager just has flimsier pipes?
Has liked: 228 times
Been liked: 602 times
Re: Motorcycle jack
The headers are double-wall and very tough. Don't know whether that's all the way back to the mufflers.
But I'd still build a simple wooden cradle to the frame, to avoid torquing the the head connectors if nothing else.
cushman eagle (Sun Oct 09, 2022 12:51 am)
Has liked: 851 times
Re: Motorcycle jack
Yes,Nails,I have also wondered about that. :hmm:
usmalenurse
2016 Honda Goldwing
Has liked: 7 times
Been liked: 41 times
Re: Motorcycle jack
Post by usmalenurse »
Someone on the forum used to make an adapter that fit on those jacks. I bought one and it works great. Front fits around behind the pipes to the frame and the rear sits under the center stand.
These users liked usmalenurse's post:
Bonnie and Clyde (Fri Dec 23, 2022 2:37 am)
Charles Hairr
1997 Voyager XII
2016 Honda Goldwing
Been liked: 235 times
Re: Motorcycle jack
With parts being difficult to find, I will not take a chance on crushing the pipes. I gave my HF Lift away, after I tried some adapters I found on the market -- they did not work.
Never occurred to me to build an adapter out of wood -- didn't see posts on this idea until after I had given it away.
If a metal adapter for HF Lifts were offered, I would buy one, and after it arrived, I would visit HF and buy another Lift. :LvStrk It would be so damned fine to be able to use that HF Lift!... Grrr! Cheers!
Bonnie and Clyde (Fri Dec 23, 2022 5:01 pm)
Van Voyager
Has liked: 46 times
Been liked: 40 times
Re: Motorcycle jack
Post by Van Voyager »
I bought one and used it, along with a couple of hockey pucks, on my Vulcan 1500. It worked fine, but it always seemed a bit wobbly and top-heavy with a bike on it. I got rid of it and just use one of those flat top scissor type jacks - use it on all mike bikes, including ZN1300 Voyager.
usmalenurse
2016 Honda Goldwing
Has liked: 7 times
Re: Motorcycle jack
Here are a few pics of my adapter on the HF lift. They just bolt onto the lift arms and easily removed if not needed. Work great with the Voyager XII
Bonnie and Clyde (Wed Dec 28, 2022 3:27 pm) • cushman eagle (Wed Dec 28, 2022 11:25 pm) • Conrad (Fri Dec 30, 2022 1:50 am)
Rating: 33.33%
Charles Hairr
1997 Voyager XII
2016 Honda Goldwing
Re: Motorcycle jack
Nice. I am going to look into making one of wood, again, come Spring. Thanks for sharing the photos. Cheers!
Bonnie and Clyde
2007 KTM Super Enduro 950
2019 KTM xcw 300 TPI
Has liked: 189 times
Been liked: 50 times
Re: Motorcycle jack
Post by Bonnie and Clyde »
usmalenurse wrote: Tue Dec 27, 2022 7:02 pm Here are a few pics of my adapter on the HF lift. They just bolt onto the lift arms and easily removed if not needed. Work great with the Voyager XII
Thank you for posting that :perfect10:
Conrad
Has liked: 25 times
Re: Motorcycle jack
Post by Conrad »
Well, started winter maintenance yesterday, and first on the list was taking the wheels off to get the new tires put on. Tried the jack, and honestly saw no problems with the exhaust pipes crushing, but it was WAY teetery and unstable. So that adaptor is definitely the way to go!
Bonnie and Clyde (Fri Dec 30, 2022 2:44 pm) • cushman eagle (Sat Dec 31, 2022 1:16 am)
