won't start.
metric
won't start.
Post by metric »
Hi guys
I try to start my 02 Voyager with a good battery and I don't get any lights or power, the main fuse is good, what other thing I should check?
"Four wheels move the body, two wheels move the soul"
02VoyagerXII AVA#5443
Has liked: 854 times
Re: won't start.
The way I would try, is to download a service manual,then use a test light following the schematic going from the battery to the key switch and see where you lose current. :hmm:
Keep us posted with what you find. :thk:
My '99 had a failure in the key switch wiring harness by the time I bought it in 2009 with 22,000 miles on it,and had already been patched up.The harness was wrapped to tight to the steering head and flexed with every move of the handle bars.
I removed,rewired,and reinstalled the harness,and have not had it fail in 13 years and 84,000 miles. :thmup:
Nails (Sun Apr 09, 2023 3:25 am)
Been liked: 104 times
Re: won't start.
Ignition switch harness or 10 pin connector.
