gauges acting weird
augwld
1
2004 Suzuki VZ800 Marauder
began build in 2016, a 49cc mini chopper/bobber
gauges acting weird
Post by augwld »
Start up, no gauges. Warms up and temp gauge starts working, then tach and fuel gauges start working. Did the Battery electrolyte to orange wire signal relay bypass. Ran a secondary wire from yellow/black igniter wire to neg. battery terminal. Cleaned negative/ground frame connection. Engine purrs. Bike runs beautifully, air shocks working,speedometer no issues. Radio is stuck on h/s (headset mode). sending to the great Pete Frachi so he can work his magic and upgrade. Why the delay in fuel gauge and tach operating?
Has liked: 880 times
Been liked: 300 times
Re: gauges acting weird
It sounds,augwld,that it may be time to go through your wiring harness disconnecting the harness at each connector,cleaning them with contact cleaner,use dielectric grease,then reconnecting them :hmm:
I think there is a post on this forum regarding this .
GrandpaDenny (Sat Jul 29, 2023 1:23 pm) • Nails (Sat Jul 29, 2023 2:48 pm)
