Where is my clutch fluid going?
glvnthedream
1
Has liked: 46 times
Been liked: 14 times
Post by glvnthedream »
My clutch fluid seems to be disappearing! I am not finding any leaks but after replacing the fluid when I got the bike I find myself having to refill the reservoir. I replaced the fluid and bled the clutch fluid and all seems good for a while. But after a couple weeks the fluid starts showing low again.
Any ideas to find a leak that is not appearing to be leaking. Where the heck is the fluid going??
Thanks in advance.
Has liked: 852 times
Re: Where is my clutch fluid going?
It may be time to repack the slave cylinder :hmm: ,as it could be going past that into the transmission :cry2:
glvnthedream
1
Has liked: 46 times
So I should check is my engine oil level is increasing to verify? Is there anything else to check to co firm?
Every job I’m doing on this lady is a first for me.
cushman eagle wrote: Sun Jan 14, 2024 8:24 pm It may be time to repack the slave cylinder :hmm: ,as it could be going past that into the transmission :cry2:
You would be adding such a small % of the total volume ,I do not think you would notice the difference :corn:
glvnthedream
1
Has liked: 46 times
Is there any other checks to verify the problem??
cushman eagle wrote: Mon Jan 15, 2024 12:51 am You would be adding such a small % of the total volume ,I do not think you would notice the difference :corn:
Has liked: 228 times
Been liked: 602 times
glvnthedream wrote: Mon Jan 15, 2024 8:52 am Is there any other checks to verify the problem??
Yes. Inspect the clutch slave cylinder as Loren suggested. See Chapter 5 of the manual.
cushman eagle (Tue Jan 16, 2024 1:13 am) • glvnthedream (Sun Jan 21, 2024 4:40 am)
glvnthedream
1
Has liked: 46 times
Will do. Ordered a rebuild kit. Figured if I am going to pull it apart I might as well do a rebuild. I can only imagine what it's going to look like.
Greg
Nails wrote: Mon Jan 15, 2024 7:22 pm
Yeah, my guess is that you're gonna need the kit.
glvnthedream (Wed Jan 17, 2024 10:34 pm)
glvnthedream
1
Has liked: 46 times
That’s affirmative on needing the kit. Oil sightglass nearly full and some nice sludge in the Slave cylinder.
Nails wrote: Tue Jan 16, 2024 10:34 pm Yeah, my guess is that you're gonna need the kit.
glvnthedream ,Since your clutch fluid looks that bad :hmm: ,you might also give a good look at your brake systems,and be prepared to rebuild them also :corn:
triton28 (Thu Jan 18, 2024 11:33 am)
glvnthedream
1
Has liked: 46 times
Already rebuilt the calipers and getting brake lines.
Thanks for the help and advice everyone.
cushman eagle wrote: Thu Jan 18, 2024 1:10 am glvnthedream ,Since your clutch fluid looks that bad :hmm: ,you might also give a good look at your brake systems,and be prepared to rebuild them also :corn:
These users liked glvnthedream's post:
GrandpaDenny (Fri Jan 19, 2024 10:24 pm) • Stew (Sun Jan 21, 2024 8:00 pm) • Scott-(Altoona, PA) (Mon Jan 22, 2024 3:09 pm)
Rating: 33.33%
