1991 XII replaced cable speedometer still not working (FIXED)
- Current bike(s): 1991 Voyager XII 47k miles
- Has liked: 2 times
Before I try to buy and throw a speedo gear on the front wheel is there anywhere else I should check on this bike? I'm new to the voyager series and was wondering maybe there's a fuse or relay for the speedo? The rest of the cluster works just not the speedo. What direction would yall go in from here?
- Has liked: 234 times
- Been liked: 621 times
Re: 1991 XII replaced cable speedometer still not working
Sounds like what you need t do is figure out what's wrong. But while you have it apart, you might want to have on hand a gear to throw in there. It's cheap.
- Been liked: 248 times
That gear is known to lose a tooth, which makes the Speedometer off, by something like 5 MPH. Nails is correct: figure out the source/cause of the problem before you throw parts at it.
If you do tear down the Speedometer housing, it would be a good time to replace the incandescent bulb (7,000 hour lifespan) with an appropriate LED replacement (20,000-50,000 hour lifespan).
If you have not replaced the majority of the incandescent bulbs with LED's, I heartily recommend it. This will free up a number of Amperes from the Charging System, to recharge your battery better, and it helps with operating accessories, as well: phone chargers; GPS systems; CB Radios; heated vests; etc. The OEM Charging System does not offer very many spare Amperes for accessories!
There are a few threads on this topic, already.
Be sure to compare Lumen outputs between the specific incandescent bulbs you are replacing, and the LED replacements you choose: make sure the LED's Lumen output is equal to, or (preferably) higher! Use the search function to find the previous threads, for more information.
You will want to use LED's which are the same color as the lens cover they sit behind.
White colored LED's will waste most of their Lumens by the non-lens colors being absorbed, or blocked, by the colored lenses: yellow LED's behind yellow lenses; red LED's behind red lenses...
Also, be aware that red LED's in the instrument cluster (Speedo, Tach), will not impair your night vision, but other colors will. Cheers!
![Woohoo :woohoo:](./images/smilies/woohoo.gif)
![Idea :idea:](./images/smilies/icon_idea.gif)
Great thanks for the replies. I did some forum digging and found the order of checks should be as follows and correct me if I'm wrong;
Pull cable from wheel hub and hook a drill to the cable end to test if the speedo actually works (should the key be in the on position for this? Or does it work regardless of power to the cluster?) If it doesn't move the cluster is likely the culprit.
If the cluster works reinstall the cable to the wheel hub and remove the cable from the cluster. Then lift the front of the bike and spin the wheel to see if the cable spins. If the cable doesn't spin with the wheel then the wheel hub is the culprit.
Now if the wheel hub is bad it is my understanding that I can swap the whole hub unit for a ninja 600 with a 23t gear for better accuracy. Is this a true belief that the housing will swap or do I have to swap the inards into my housing to get this to work?
- Has liked: 491 times
- Been liked: 444 times
Just get the thingie on the wheel. It's CHEAP and known to wear out. Don't do like I did and let a "mechanic" charge you fifty bucks to check it and say "oh yeah it's a little chewed up, but they get that way". Dumbass... I'd even given him the new one. If it looks at all worn or chewed up, just put in a new one.
2008 Ford CVPI
SJ Retreads, PGR, WWR
2008 Ford CVPI
Yes that's what I was thinking, Is it true that there are several Kawasaki models that are direct bolt on? finding a new Voyager oem part is proving to be a bit difficult and expensive. I found a list of bikes that are "cross compatible" but my question is, is it just the gears that are cross compatible or is it the entire hub that will swap over?GrandpaDenny wrote: ↑Fri Mar 15, 2024 7:06 pm Just get the thingie on the wheel. It's CHEAP and known to wear out. Don't do like I did and let a "mechanic" charge you fifty bucks to check it and say "oh yeah it's a little chewed up, but they get that way". Dumbass... I'd even given him the new one. If it looks at all worn or chewed up, just put in a new one.
- Has liked: 114 times
- Been liked: 289 times
With respect to the Ninja 600 of say 1997, it will be a direct, speedometer wheel hub gear case assembly interchange: take the old one off of a Voyager XII and install the complete 23 tooth ninja 600 assembly. Any year/model speedo wheel hub gear case assemblies having the same part # 41078-1062 will also interchange complete.
I have also gone the route of changing the 25 tooth Voyager XII gear in the original Voyager XII housing with a 23 tooth gear to correct the speedo error. The worst part was drilling the relief hole for the roll pin to be driven out through. See article in the Tech Center; Voyager XII concerning speedo error.
triton28 wrote: ↑Sat Mar 16, 2024 12:39 am With respect to the Ninja 600 of say 1997, it will be a direct, speedometer wheel hub gear case assembly interchange: take the old one off of a Voyager XII and install the complete 23 tooth ninja 600 assembly. Any year/model speedo wheel hub gear case assemblies having the same part # 41078-1062 will also interchange complete.
Awesome thanks for the confrimation I am just going to order the whole housing and bypass the drilling part
![Worship :bowdn:](./images/smilies/bow2.gif)
Thanks for putting in the effort to wrap your head around this little job, just to write a comment. Like the specific number of teeth -- a detail my lizard brain certainly let slip. Another thing ... drilling out that little hole was so trivial that I completely forgot about it, too.triton28 wrote: ↑Sat Mar 16, 2024 12:39 amI have also gone the route of changing the 25 tooth Voyager XII gear in the original Voyager XII housing with a 23 tooth gear to correct the speedo error. The worst part was drilling the relief hole for the roll pin to be driven out through. See article in the Tech Center; Voyager XII concerning speedo error.
I'm too lazy and just think that it's all discoverable in here.
https://www.amervoyassoc.org/forum/view ... &hilit=23t
CHECK THIS POST OUT^^^^For anyone having a similar issue
I did a little digging and found the post that cross references all the Kawasaki models that will have a working gear and housing assembly for the XII. I ended up finding a 2007 250r hub assembly on eBay that I offered the guy 10$ for and he accepted. I will update how well this works out once I receive the item.
Problem SOLVED
The speedometer gear assembly was wrecked, turns out The speedometer receiver housing was also wrecked. So I ordered a NOS receiver from eBay for about 18$ and a used 2007 Ninja 250 Speedo gear for 10$. Replaced the cable for good measure but kept the old as a spare. works like a charm.
Problem SOLVED
I agree! I couldn't have done it without everyone here's collective knowledge. I am so glad I stumbled across this forum and all the willing to help people that are involved. You guys are the best!
