Cruise control
ted1r
1
Has liked: 92 times
Been liked: 35 times
Cruise control
Post by ted1r »
Hi Guys ,just a quick question .whilst out the other night I was on a four lane section of road doing about 70mph at which point I tried the cruise
which abruptly brought me down 55 :tho: Is this normal ?no end of fiddling would increase the speed,
any help guys
Ted
Been liked: 238 times
Re: Cruise control
Check the cable tension in the actuator. There are videos for this adjustment on YouTube, along with threads here on it.
If the cable tension is not the solution, then it might be an actuator/control box issue. Start with the simple/easy, and work towards the complex/expensive end of the spectrum. Cheers!
:thmup:
cushman eagle (Tue Apr 02, 2024 12:13 am) • ted1r (Tue Apr 09, 2024 4:36 pm) • Stew (Tue Apr 09, 2024 6:47 pm)
Rating: 33.33%
ted1r
1
Has liked: 92 times
Re: Cruise control
Post by ted1r »
MANY THANKS SIR
TED
Re: Cruise control
You are most welcome.
The actuator cable tension slips, over time. This is the usual suspect, and it is not too difficult to adjust. It makes a world of difference, relieving a host of stressors -- I just wish the other life stressors were so easy to relieve! :roll: Cheers!
cushman eagle (Thu Apr 04, 2024 12:31 am) • ted1r (Fri Apr 05, 2024 1:14 pm)
ted1r
1
Has liked: 92 times
Re: Cruise control
Post by ted1r »
MANY THANKS ,all sorted after a bit of fiddling :woohoo:
TED
These users liked ted1r's post:
cushman eagle (Tue Apr 09, 2024 10:09 pm)
