Temp gauge sluggish/twitchy even with new ground?
- Heavy Armor
- Has liked: 10 times
- Been liked: 25 times
So my temp gauge will gradually creep up to the warm mark, but even on a hot day in the 90's will not climb any higher. It also has a bad habit of wiggling, ticking, and sometimes diving to zero. The old negative wire seemed to have good connection, but just to be safe I replaced it with a brand new ground tied directly to the battery. Made sure the positive terminal was clean. No change, still slow and twitchy. What do you think could be causing this? Just a bad sending unit?
- Has liked: 851 times
Re: Temp gauge sluggish/twitchy even with new ground?
It could be a bad connection anywhere from the sending unit through the harness to the guage.
Do you have a service manual with which you could follow the schematic?
There is a site on this forum from which you can download one if you have non
- Has liked: 480 times
- Been liked: 435 times
It's in my .sig below
