Change speedometer cable still not working
jwcpastor
Current bike(s): 2003 Kawasaki Voyager 1200 XII
Has liked: 7 times
Re: Change speedometer cable still not working
Post by jwcpastor »
I have a new dilemma. I changed out the inside piece that was broken greased and changed brake pads, put everything back together, and I noticed that when Turn the Front wheel Forward speedometer cable won’t turn, but when I turned the wheel backwards, the cable turns so my question is do I have something backwards? I didn’t think that I did because I put everything back the way it Came apart. Can somebody please tell me what I’m doing wrong thank you.
Has liked: 228 times
Been liked: 602 times
Probably not sticking the inner cable in far enough. You usually have to turn it to line it up.
cushman eagle (Fri Aug 23, 2024 12:13 am)
Has liked: 83 times
I agree with Nails, it sounds like the inner cable isn't completely seated and when the handlebars turn it slips just enough to not engage. Just separate the cable at both ends (one at a time) and re-seat it. You should feel it slip into position.
