Goo melting out of windshield
MonsterMash479
1
Current bike(s): 1996 Kawasaki voyager xii
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Post by MonsterMash479 »
Parked my 96 for a couple weeks after a particularly hot couple weeks here in jersey and when i took the cover off today i find this goop running all down the side of my bike. Is this just a bad repair from prior owner or is this a known problem?
teteague
1
Current bike(s): 1992 Voyager 1200
1977 KZ1000
1981 Honda GL500 Silverwing with sidecar
1982 KZ550LTD
1996 Honda ST1100
2001 Indian Spirit
Has liked: 4 times
Been liked: 5 times
Re: Goo melting out of windshield
Post by teteague »
I’ve never actually seen a voyager windshield with trim around the edge, I would presume it’s whatever glue is holding the trim on that is caused that issue. Maybe try something like mineral spirits that won’t damage the windshield itself to clean it up?
These users liked teteague's post:
Nails (Sun Aug 18, 2024 5:24 pm) • triton28 (Sun Aug 18, 2024 5:38 pm)
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Okay cool good to know i was very confused by it cause it sits right in my line of sight so i have to look over or under the trim
These users liked MonsterMash479's post:
teteague (Sun Aug 18, 2024 5:50 pm)
Been liked: 249 times
I've seen this before. I believe it is the foam tape's glue partly melting with both age and heat. The trim is secured around the plastic windshield's edge, using double-sided foam tape.
Most Voyagers do not have any trim around the edges of the windshield. If the trim is coming loose, or off, it may be necessary to remove it, then clean it up with something like Goof-Off solvent/cleaner, if turpentine/mineral spirits does not do the job.
You can search the Internet for black, double-sided, foam tape, if you want to re-install the trim. It will be a lot of fiddly work, with a learning curve.
You could also fill the trim with clear silicone, using a caulking gun. After you press it around the edge of the windshield, you will need to wipe away the excess silicone that oozes out, to avoid making a mess on the edges -- this should last 20 years. Up to you. I wish you the best of luck. Cheers!
:thmup:
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
No i want to throw the trim in a fire, it sits right in my line of sight when im riding so i eiether have to straighten up and look over it or slouch
Has liked: 242 times
Been liked: 631 times
Or cut the windshield shorter.
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
I’m gonna get a new slipstream windshield and be done with it. I spent two hours in the tub scrubbing the glue with every chemical i could find and can’t get it to release so, time to start fresh :bat:
ted1r
1
Has liked: 100 times
Been liked: 38 times
Post by ted1r »
Hi Guys ,that was an interesting storey .never thought a1200 would have a trim .
Ted
Has liked: 506 times
ted1r wrote: Wed Oct 16, 2024 4:48 am Hi Guys ,that was an interesting storey .never thought a1200 would have a trim .
Ted
They didn't. Some PO added it. S'pose they thought it would "look cool" nevermind it being right in the field of vision.
ted1r (Wed Oct 16, 2024 11:25 am)
Been liked: 108 times
Slipstreamer are good windshields. I have them on 2 of my voyagers. They hold up well. Better than OEM.
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
New windshield is getting delivered tomorrow, I’ll update you once I get it on the bike
Has liked: 119 times
Be cautious regarding the mounting screws and especially the steel collars as the OEM windscreen is thinner than some aftermarket windscreens. This condition may/can lead to the collars being at the stress point of the plexiglas/acrylic when the screws are being tightened down on a non OEM windscreen install, and the collar is not long enough to bottom out when the windscreen is tight against the cowling. If one does not account for this windscreen/collar bottoming out length sometimes a crack may/can occur at the point of contact between the collar, the windscreen and the cowling.
Most times I suspect this doesn't occur but it has happened to me for the reason I outlined.
Just a heads up,
GrandpaDenny (Sun Oct 20, 2024 6:56 am) • Nails (Sun Oct 20, 2024 9:56 am)
I have had no problem installing my slipstream windsshields. Have had them off and on many times.
MonsterMash479
1
2023 aprilia rs660
Has liked: 2 times
Been liked: 5 times
Its on the bike, i just snugged up the screws good, via the ol german torque spec. So far it feels like theres way less air hitting my head with the new slipstreamer. Definitely worth the $140
triton28 (Tue Oct 22, 2024 4:55 am) • GrandpaDenny (Tue Oct 22, 2024 9:30 am)
