Light fuel tank rust solutions?
Cherryriver
4
Current bike(s): 2009 FJR1300
2000 VFR800
1999 CBR1100XX
1986 ZG1200
Permitted to maintain the Missus' Ninja 1000LT
Been liked: 4 times
Post by Cherryriver »
I'm getting back to planning for the '86 I picked up at an estate sale a couple of years ago. It only has 6000 miles and is complete and cosmetically pretty decent.
The carbs, however, were atrocious and I haven't had much luck with going after them. Upon reassembly they were leaking gushers.
I know better, and will need to get back at them.
I know I'll be getting the fuel tank out, in order to replace the fuel line at the bottom exit. The original crumbled into almost dust when I went to disengage it.
I peered into the tank best I could and don't see any drastic flakes of rust, but the walls are pretty red.
I have seen plenty of methods but I'm willing to listen to any suggestions. It seems to me that getting the detritus out of there after a cleaning could be a problem given the shape of the tank.
I think the tank's salvageable- I've see a lot worse- but as long as it's loose I think I ought to do something.
Bill
Van Voyager
Has liked: 51 times
Been liked: 44 times
Re: Light fuel tank rust solutions?
Post by Van Voyager »
Evaporust is your friend.
If it's going to need more than just de-rusting, then the POR motorcycle tank kit is a good option (I've used it successfully in the past with great results - everything still looking good after more than 20 years).
At the risk of stating the obvious; you'd want to remove the sender assembly first.
triton28 (Sun Dec 03, 2023 9:45 pm) • Nails (Sun Dec 03, 2023 10:43 pm)
Has liked: 241 times
Been liked: 624 times
And while removing the sending unit, test it to see if the low fuel light comes on when above any fuel level. (Dunno if '86 had this.) These commonly die, but you'd never know until it's too late. Cheap and easy repair. Check Dollar4Dollar, or search here for "Mustang".
Has liked: 117 times
Nails (Mon Dec 04, 2023 4:04 pm)
I picked one up for less than that at the local NAPA store. They pulled it right off the shelf -- I just brought in a part number that I found here.
Been liked: 106 times
What is the part number that you got it from NAPA ?
For heaven's sake, I can't remember whether I took my pills yet today.
I found this alternate part on here somewhere, but I can't find it again now. Maybe I just asked NAPA for a low-fuel sensor for a 1967-1973 Mustang or Cougar, as Dave mentioned here (viewtopic.php?p=92707#p92707). It should look exactly like OEM; and then it'll perform exactly like OEM.
Sci_
Current bike(s): 2001Kawasaki Voyager XII
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
How to remove rust in a motorcycle gas tank.
I had bought a 2001 Kawasaki Voyager XII that had sat in a garage for 8 years and the gas tank was plum full of rust. I researched hours and hours before I came up with the best way to handle the rust.
First off, vacuum tank, inspect with 7 watt Xmas tree lamp and small swivel mirror. Power wash, inspect. If it’s real rusty, use the nuts and bolts trick or a chain to get rid of the bulk of the rust flakes. I took turns shaking the hell out of mine with my sons taking turns (I didn’t have a dirt bike to strap it to and take it out for a rough ride to bounce the crap out of it).
Put a 50/50 mix of phosphoric acid & water in the tank and seal it up good (it will ruin paint). Swish around, rotate occasionally and let work for about 8 hrs. Always add ACID TO WATER-NEVER add Water to Acid.
Empty tank. Rinse with water and then fill it with a solution of water and a ½ box of baking soda to neutralize the acid. After 15 minutes, rinse the tank again with water.
Immediately rinse with ½ gal gas with an once of Heat.
Next rinse with pre-mix gas (25:1, gas to 2 cycle oil), swish around.
Notes:
-TSC sells slightly diluted phosphoric acid by the gallon. Cheap. Whatever you buy, make sure it has phosphoric acid in it, and not sulphuric acid or something else like that.
-Phosphoric acid converts rust to iron oxide that is rust resistant.
-You can dilute the discarded Phosphoric acid again and put it in your garden.
These users liked Sci_'s post:
Nails (Fri Mar 15, 2024 2:34 pm) • GrandpaDenny (Fri Mar 15, 2024 7:02 pm)
Has liked: 501 times
Been liked: 450 times
Sci_ wrote: Fri Mar 15, 2024 2:10 pm -Phosphoric acid converts rust to iron oxide that is rust resistant.
Huh? Rust *IS* iron oxide.
1977 Com-Pac 16 "Hesperus"
Sci_
1982 Harley FLT
1997 Harley FLHP
1993 BMW K75
2009 Yamaha XT250
Has liked: 7 times
Been liked: 6 times
Post by Sci_ »
GrandpaDenny wrote: Fri Mar 15, 2024 7:04 pm
Good catch. My bad. I should have said phosphoric acid converts iron oxide (rust) into a layer of iron phosphate which then acts as a protective coating.
Sorry about that,
Sci
Sci_ wrote: Fri Mar 15, 2024 9:08 pm
Sorry about that,
Sci
Oh, ok so is that what rust conversion solutions use? If so, will your tank turn black inside?
GrandpaDenny wrote: Sat Mar 16, 2024 11:14 am Oh, ok so is that what rust conversion solutions use? If so, will your tank turn black inside?
My take-home: The rust stuff I've used -- that turns rusted metal into a black, paintable substance -- is a gel, not something I'd want to slush around in the tank. And "by the gallon" sounds a lot cheaper.
I've never looked up this chemistry. But I did notice a warning that using it on steel that isn't actually rusted can cause rust. Maybe the careful rinses take care of that. (At the time, I was working on the inside of doors that had "cancer" along the bottom.)
GrandpaDenny (Mon Mar 18, 2024 9:24 pm)
morgan21
Post by morgan21 »
This bike is a good project, especially with only 6000 miles and all the parts still there. The carburetors probably need a full cleaning and new parts like gaskets and float valves to stop the leaking. For the fuel tank, if the inside looks red but doesn't have big rust flakes, it's likely just surface rust. You can try cleaning it with vinegar or a rust remover like Evapo-Rust. After that, rinse it well with water and use air to dry it and blow out any loose bits. Since the fuel line already broke apart, it’s a good idea to clean the fuel tank marine-grade now while it’s off the bike. Taking care of these things will help get the bike running right again.
forestfarm61
Current bike(s): 91 zg1200
Post by forestfarm61 »
white vinegar is your best friend,few gallons,let it sit a week,voila.just be sure to shake some pre mixed oil/gas around in there afterwards,or some diesel fuel as the newly clean steel will flash rust if left exposed to air
