Another brand newbie intro/question...
Been liked: 235 times
Re: Another brand newbie intro/question...
Been told that only replacing front/rear suspension will make the weaknesses of the remaining OEM, glaringly obvious... Both suspension systems work together: best to upgrade both, same time. The Progressive Fork Springs are nice... Cheers!
timmerz_1
Current bike(s): 2000 Honda XR650R
1989 Kawasaki Voyager XII
Post by timmerz_1 »
SgtSlag wrote:Been told that only replacing front/rear suspension will make the weaknesses of the remaining OEM, glaringly obvious... Both suspension systems work together: best to upgrade both, same time. The Progressive Fork Springs are nice... Cheers!
I'm sure that's true! My problem is that mechanically I am limited in my skilz...I can handle bolting-up the shocks, but get me into taking forks apart and it's game-over...that's where I bungle stuff up, and it costs me twice as much to get it done...my plan is to get the shox installed and then budget the Progressive springs and then the install fee for a proper mechanic to do it so it's once and done for me...
...which leads me to my next question: does anybody have a favorite bike mechanic in the Central Ca. Valley area that will do good work on an older bike like mine? I live in Manteca, but for a decent mech, I would drive a ways...
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
Front fork springs are easy.
http://www.abbikeboard.com/jeff/spring/spring.html" onclick="window.open(this.href);return false;
Me Again
Been liked: 262 times
Post by Me Again »
I have heard this numerous times on this forum. With the help and instructions from other members what seems impossible becomes a simple project.
Front forks is one of the scary things most have ,but by following the instructions here they appear to be just ordinary wrenching.
Ask a lot of questions and then give it a try.
timmerz_1
Post by timmerz_1 »
Hmmmm...my other problem is, I'm easily swayed and led astray...LOLOLOL!!!
Let me see how badly I snafu these shocks, I already see some questions I have, just from un-packing them...what are all these rings for? Are they inserts for a snug fit on top and bottom holes?
Me Again
Post by Me Again »
timmerz_1 wrote:Hmmmm...my other problem is, I'm easily swayed and led astray...LOLOLOL!!!
Actually that's a very good start.
Check the pics in Voyager55's post and get them lined up correctly.
I have read that the hardest part is removing the C-clip
Check the pics,that's a pretty nice home made prybar .Some people like to get a helper to hold the cap down while they remove the clip .
Follow the instruction and take some pictures as you go to help in reassembly.
OOPs ,I was thinking forks and you were talking shocks . Sorry
Has liked: 106 times
Been liked: 274 times
Some makes of rear shocks come with various sized mounting bushings to accommodate the different mounting studs/bolt sizes, which is the ID of the bushing. The OD would all be the same for the shock upper eyelets and may also be the same OD for the lower eyelets.
timmerz_1
Post by timmerz_1 »
Thanks, Dave!
