Voyager radio
- Has liked: 106 times
- Been liked: 277 times
Re: Voyager radio
Also note that if you suspect a stuck seek switch on the handlebar, the handlebar switch would override the jumpering test. You would have to disconnect the switch for any function which appears NOT to be in a static/neutral position before jumping the connector pins at the radio end as shown in the illustration.
- Tonyvdb
1996 Voyager (Just sold)
Re: Voyager radio
The only odd thing about the seek switch is it does not start to seek until I push it and if I change directions to seek down instead of up it also changes direction so I don't think it's stuck.
1981 Kawasaki GPZ550 (sold)
- vxiirider
- Tourer
- Current bike(s): 2002 1800 Goldwing Trike
- Has liked: 91 times
- Been liked: 28 times
Re: Voyager radio
This may be a dumb response but have you checked that the fader knob is turned all the way to the front speakers ?
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
Charlotte, Michigan
- Tonyvdb
Re: Voyager radio
I'll try anything so no such thing as a dumb question :)
But yes, I've even moved it back and forth and can hear static in the speakers as I do it. That's why I'm am sure the amp is working (can hear the relays click when I power on the radio as well)
- Bill O
2003 1200 Voyager
- Been liked: 6 times
Re: Voyager radio
Has anyone mentioned if the "HS" button problem. The radio may be switched to "Head Sets" Check to see if the HS indicator is turned on on the radio face. If this has been identified earlier, I apologize for jumping in..
Bill O
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
- Tonyvdb
Re: Voyager radio
Yup, checked that as well:)Bill O wrote:Has anyone mentioned if the "HS" button problem.
- Tonyvdb
Re: Voyager radio
Update:
Took the wiring harness apart to the handlebar control and jumpered the volume leads and low and behold the volum went up and down
So now the radio works but I will need to troubleshoot if it's the actual volume control or the wire. The harness connector was full of water, not good so will dry it out and see if it works after connecting it again.
My nex search is the antenna as that is also not working. I think it's a broken wire but not sure yet where or if it's fixable.
