Reassembly sequence 93 voyager carbs
grumpy72
99 shadow 1100
93 voyager 1200
Been liked: 15 times
Re: Reassembly sequence 93 voyager carbs
Post by grumpy72 »
I am screwed. Whoever jacked woth my carbs before screwed up everything. The accel cable that mounts in the bottom most channel on the carbs slides into a channel, the cable slides between the halves, the barrel pops in the hole.the adjuster and lock nut fit in a bracket above it. The bottom cable is so hard to get to the guy pried it open to get the barrel out. When i tried to straighten it the outside piece broke off.
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
Maybe i am not screwed. I have the do it yourself cable repair kit with cable, barrels, setscrews . I think if i jb weld a barrel end wise to the existing barrel then instead of being flush it sticks past 1/8 inch. Then put setscrew into additional barrel.then the whole thing cant slip out of the hole.what do you think?
Has liked: 234 times
Been liked: 621 times
Assuming they sent you the right cables ... they are difficult to put back on and you might be giving up too soon. But dunno, I wasn't there.
Has liked: 491 times
Been liked: 444 times
Hey I have nothing but praises for my 22 years old $800 bike. She was very sad looking and in fairly crappy shape when I got her. It has been a pleasure (mostly) fixing her up and, most of all, riding her. 54,000 miles on her in November 2019 when I got her, now she's got over 93,000 and rapidly climbing.
Enjoy!
BTW Kawasakis in general seem to be known for brittle frame bolts. I found an interesting surprise one day at Gene Kapuszinski's house; one frame bolt had been replaced with a long skinny machine screw and the other was missing. These were the bolts holding on the entire rear subframe.
2008 Ford CVPI
SJ Retreads, PGR, WWR
