how do i change anti freeze
- Current bike(s): 1989 voyager zg1200
what is the best way to change anti freeze bike runs too warm when in traffic on a hot day.ive had the bike for three years and love it now i need to do some things to it
Re: how do i change anti freeze
- Has liked: 106 times
- Been liked: 274 times
If you have had the bike for 3 years then the cooling system probably has more than that amount of service time. I would recommend flushing the system before installing new coolant. Remember, if you don't use premixed coolant, to use demineralized or at least distilled water to get the proper ratio.
- Current bike(s): 2003 1200
Change coolant every 2 years no matter what. Same with brake/clutch.rear gear oil
I use Peak 50/50 coolant.
thanks so very much for the manual.i can now print out chapters as i go..you guys rock!!Mr Jensee wrote:See page 3-4 https://c7vpuw.bn1303.livefilestore.com ... pdf?psid=1
thanks so much for the manual.Mr Jensee wrote:See page 3-4 https://c7vpuw.bn1303.livefilestore.com ... pdf?psid=1
