radio
wsm 1
Current bike(s): 1998 gl 1500 SE 2002 voyager xii
radio
Post by wsm 1 »
Well changed plugs today and radio won,t come on ,time will display but no radio or change channels.I wonder what I did wrong? Any help please. Thanks :bat:
Tonyvdb
1996 Voyager (Just sold)
1981 GPZ 550 (Previous bike)
Re: radio
Post by Tonyvdb »
There are two power connectors behind the radio, must have been pulled loose. (both have fuses)
1981 Kawasaki GPZ550 (sold)
wsm 1
Re: radio
Post by wsm 1 »
Ok ,thank you .I will give it a look.
wsm 1
Re: radio
Post by wsm 1 »
I looked at the fuses and they are medal on the ends and plain glass in between ,is that how they are to look? I am getting power to radio but no sound,any ideas? :bat:
Re: radio
Any chance the passenger mute button is depressed? Also make sure he HS button is not depressed. That is exclusively for a head set.
wsm 1
Re: radio
Post by wsm 1 »
I removed the rear controls and speakers.The radio was working till I changed the plugs,must have pull something loose.
Been liked: 134 times
Re: radio
removing the battery , you loose all memory. ie. VOLUME,STATION, AM/FM
turn the volume up from the handle bar control.
There are four fuses to the audio system.
the glass buss fuses will have a metal, wire between the ends.
wsm 1
Re: radio
Post by wsm 1 »
I know of three fuses ,where is the fourth? You have two in line under dash and a 3amp in fuse box.Looking for number four.
Dnjiemor
Current bike(s): 1995 Kawasaki voyager zg1200
Re: radio
Post by Dnjiemor »
wsm 1 wrote:I know of three fuses ,where is the fourth? You have two in line under dash and a 3amp in fuse box.Looking for number four.
There is also one in the power amp located on the side the air valves are on
wsm 1
Re: radio
Post by wsm 1 »
Thank you ,that would be number 4.
wsm 1
Re: radio
Post by wsm 1 »
Got my radio working ,find a wire unplugged ,now it works from handlebars only but it works . :hmm:
Re: radio
Click on the link in my signature and you will find a radio manual you can download. It will give you all the functions of the radio.
