I found this rough sketch today. I had made it for a machinist friend so that I could replace the bronze lever bushings as mine were just about worn out. The steel bushing driver will push the old bushing out into a large enough deep socket being used as a spacer in a vise.
Then the new bushing can be pressed into the empty lever opening with the same vise but minus the driver and socket.
Should the installation require minor reaming, some 220 grit sandpaper on a #1 or 2 phillips screwdriver shaft will clean it up well.
clutch/front brake lever bushings
- Highway Rider
- Webmaster
- Been liked: 39 times
Re: clutch/front brake lever bushings
The reason that these only showed the address was because this is what you had [image] address [ /image]
Should have looked like this [img]address[/img]
