Loss of power after 2000 rpm
billgillin
Current bike(s): 1994 Voyager XII 1200 four
Post by billgillin »
Hi all. I've been blessed to be riding a 94 with just over 55k since 2002. I love the bike and have made some improvements including switching to full LED, mod'ed radio and phone holder and charger. However I'm writing now with an engine problem. The bike was running fine and then loss of power on throttle up. A slow steady add power gets me to about 55mph but any quick power boogs the bike down. I can hear some misses at idle but the bike starts right up and idles fine except for a random slight miss. I replaced some faulty plug boots but that didn't fix it. Does this sound like fuel or fire? Any help will be appreciated.
Has liked: 105 times
Been liked: 274 times
Re: Loss of power after 2000 rpm
Fuel, for my money.
More specifically, I would say the fuel filter is dirty.
Just a guess.
Avidrider62
Tourer
Tourer
Current bike(s): Bikeless
Post by Avidrider62 »
Check for a hole or crack in the hose going to the ecm module. That's your spark advance .
2003 with 87 colors
billgillin
Thank you both for the good info. The fuel filter is fairly new but I'll check fuel flow to the carbs. I have been leaning towards a fire issue. Spark advance is a good scenario to check. Now to find the ECM and hose... lol. Has anyone had this problem?
scottolds
2009 Kawasaki KLR650
2011 Ural Gear Up
1987 Honda Super Magna
Post by scottolds »
Look under the faux tank cover on top of the air cleaner box cover on the right hand side as you are sitting on the motorcycle.
You will see the ignitor with two wiring harnesses plugged in and a vacuum line which goes into a check valve and then I believe it ends up at a vacuum port on the left most carburetor.
