Fender washers
odgreen
Current bike(s): 1993 Voyager XII
1994 Voyager XII
1989 HD FLHS
Fender washers
Post by odgreen »
Getting ready to install progressive spring on the front, change the shock oil and new front wheel bearings. I am going to pull the front fender to clean it up. What is the part number for the front fender washers that I need to replace. Could not find them on the parts breakdown on "Babbitts"
Thanks in advance.
ED
Has liked: 852 times
Re: Fender washers
Send a PM to ekap1200[Gene] he makes and sells them :thmup:
odgreen
1994 Voyager XII
1989 HD FLHS
Re: Fender washers
Post by odgreen »
Thank you Cushman Eagle , PM sent.
Ed
voyager55
Current bike(s): 2003 1200
Re: Fender washers
Post by voyager55 »
http://www.partshark.com/oemparts/p/kaw ... 745/collar $3.92 each Any dealer can order them or they might stock them
Re: Fender washers
... but... but... but, he really wants Gene's stainless steal inserts to keep the
front end solid!!!!! The stock ones squash...... Make sure to talk to Gene!!!
voyager55
Re: Fender washers
Post by voyager55 »
I never had any squash in 12 years
crankyb wrote:... but... but... but, he really wants Gene's stainless steal inserts to keep the
Eydugstr
Current bike(s): 1990 Kawasaki Voyager xii
2005 Kawasaki Concours
1972/77 CB750
Been liked: 5 times
Re: Fender washers
Post by Eydugstr »
+1 for Gene Kap's washers.
It's pretty easy to check your old ones. Just pop the caps off of the fork brace, unscrew one of the bolts and remove the washer. If it's chewed up replace all four. You can go the OEM route but they aren't as good as quality as Gene's.
