Radio
- joerod777
- Current bike(s): 2003 Voyager XII
Radio
I have a 2003 Voyager and I took it in for state inspection. Radio was working fine when I took it in. Now the radio is dead. Only the time displays. Any thoughts? If the fuse is bad would the clock still work? Thanks.
JoeRod
Re: Radio
There are two fuses behind the headlight, only one is for the clock. There is also a blade fuse in the fuse box behind the battery. The two behind the headlight are glass fuses. if all your fuses ae fine, make sure your radio isn't set to HS and the tape deck button on the handlebar isn't pressed in. It happens more than you think. If you need a copy of the radio manual click on my signature.
- Avidrider62
- Tourer
- Current bike(s): Bikeless
Re: Radio
Also fuse may look good. The ends of the glass fuse may be bad. I experienced that issue myself.
2003 with 87 colors
