Help
tiredofbs4
Current bike(s): 1985 Kawasaki Voyager 1300
2005 Yamaha Majesty 400
Help
Post by tiredofbs4 »
Yesterday came out of gym. Hit start button, she fired up quick as always,but then shut down. No dash lights, no radio, no clicking nothing. Tried jump start nothing.friend put meter on battery and fuses all good. Now when I went to push bike a bit closer to try jump start I had key turned to Acc, and radio static came on, but wont if key turned to on. No on off switch not off either
Me Again
Been liked: 262 times
Re: Help
Post by Me Again »
Three quick things to check would be
Kill switch .I think the lights stay on for that .
Main fuse or main relay .
Ignition switch .Turn the bars back and forth a little and see if it lights up .
Or it could be as simple as a loose battery connection.
Good luck
Me Again
Re: Help
Post by Me Again »
You posted this in the XII forum but your profile says 1300
Has liked: 855 times
Re: Help
If you have a VXII (1200) you have the symptoms of a bad ignition switch wiring harness :cry2: Some of them were tied too tight to the steering head,and as the front wheel was turned would stress crack some of the wires in the harness,breaking contact.When I bought my '99 with only 22,000 miles on it,repairs had already been done on it.I have since had all new wires put in the harness.I did not tie it fast to the head when I reinstalled it. :thmup:
If you have a 1300,I do not have any experience with that harness. :thk:
Me Again
Re: Help
Post by Me Again »
The 1300 harness has the same problem as the XII but not as often . They just do not want to give you that extra inch of wire
