fuel line question
jake100
6
Current bike(s): 92 voyager
fuel line question
Post by jake100 »
is there a screen or sock on the pickup tube in the tank? my bike seems to run good up about 5k then it just feels like it runs out of gas , let off the throttle and it still struggles for a long time
Been liked: 134 times
Re: fuel line question
There is a fuel filter right at the fuel pump, have you replaced it ?
Have you drained the carb bowls to look for rust and or water ?
Been liked: 239 times
As a follow-up to what ekap1200 suggested, I'd run SeaFoam through the gas tank, every month, per the instructions: dissolves varnish deposits, burning the residue in the engine; absorbs small amounts of water in the fuel system; stabilizes gasoline for up to 24 months. I use it to mothball my bike for the Winter storage months, and monthly during riding season, as a PM. Costs around $9 per16 oz. can. Other than needing new Float Needles once, I haven't had a carb issue since 2010, when I bought the bike, been using SeaFoam ever since. In the Spring, it starts like I parked it last week (after the gas reaches the floats and the carbs -- dries out during storage). Cheers!
jake100
6
Post by jake100 »
Yup changed the fuel filter twice and use seafom, have opened the drain screws, but have not removed the bowls yet
