Bolt Size?
madmax
Current bike(s): 2 x ZG1200 B3 & B7
1 x ZG1000 - GTR1000
1 x ZG1400 - GTR1400
Bolt Size?
Post by madmax »
Hi, does anyone know what the thread /pitch of the bolt that goes into the swing arm & locates into the rear caliper plate to stop it rotating is?
The Bolt part number I think is 92002-1665.
There is a recess in the swing arm for the bolt to go into.
I need to find a ‘Tap’ to re-cut the thread in the swing arm after galvanizing got onto the hole.
All I know is that it’s a fine thread. But which fine thread I don’t know.
Maybe someone out there knows the answer.
Re: Bolt Size?
If you have to tap new threads anyway you may as well cut it to the next larger metric size. If you still have the bolt take it to a cycle dealer preferentially one that sells metric bikes and see if they can match it, but looking at the Voyager schematic it shows it to be an 18mm bolt.
Has liked: 109 times
Been liked: 281 times
Re: Bolt Size?
The thread pitch is 1.5; diameter 18mm
madmax
Re: Bolt Size?
Post by madmax »
Thanks for the info, most appreciated .
