cracked corner on trunk lid
- Rhbrandy
- Current bike(s): 1996 voyager xii
2008 Vulcan 900 LT - Location: West Milford, NJ
hello all, have a crack on corner of trunk lid , front corner right side. what is the best glue or way to repair it? . thanks for any suggestions. Rich
- Has liked: 228 times
- Been liked: 602 times
Re: cracked corner on trunk lid
It's ABS, and you can get the glue at any hardware store. It's easy to repair, and the repairs are strong. You might want to use a Dremel and little wire wheel to cut a curf along the crack so that the glue gets in there a little. Put the glue in with a toothpick, and then find a way to live with the black line.
I had a lot of these repairs all over my bike, including some with a lot of continuous stress. I mean, I had to torque on parts to close the crack, and then glued it. It stayed together after I took the torque off. Ended up repainting the whole thing white, just like my GMC pickup I was also repainting. Was cheaper and otherwise better than fussing with that 2-stage candy paint.
