7.5 fuse
Hadyn
Current bike(s): 1990 Kawasaki Voyager
7.5 fuse
Post by Hadyn »
Trying not to as the same questions on the radio. But I have replaced the 3amp and 1 amp looked at the amp on the amplifier it's good. Is there another amp around the Cruse control module. A 7.5 amp.
Also how do you turn off the he on the radio.
I can not find the passenger control to check the mute.
Also does the clock stay on when the ignition is off.
Thanks
Re: 7.5 fuse
Hayden the clock remains on when the ignition is off. If I remember there are 2 fuses just behind the radio. If you dont have passenger controls then dont worry about the mute there. The only mute you have to worry about is the one on the handlebar which has been known to not work if the bike was left in the weather a lot.
Hadyn
Re: 7.5 fuse
Post by Hadyn »
Thanks
