Clutch friction plate replacement
shifterkart26
Current bike(s): 94 ZG1200
Post by shifterkart26 »
Has anyone here done a clutch friction plate (only) replacement on a 94. If so, is it a straight forward process like most bikes?
Has liked: 890 times
Been liked: 313 times
Re: Clutch friction plate replacement
I had a rattle in my '99 early this year,which I incorrectly thought may have been loose tangs on my discs. :hmm: To check them out,I removed them, which checked out to be in specification.So,yes it is very straight forward with no special tools needed,other than a torque wrench. :thmup:
At that time,it had 79,000 miles on the original discs,and they were well within specs.
The rattle turned out to be a loose bolt which holds the alternator drive coupling on.
shifterkart26
Thanks Cushman!
