Front fork question
Hillbilly
Current bike(s): 98 Voyager xii
2021 versys
99 KLR650
Has liked: 27 times
Front fork question
Post by Hillbilly »
Hi everyone, I was doing an oil and seal change on my forks, and when I drove out the old seal to remove the inner barrel of the fork the end of the valving where the bolt goes into the bottom of the fork came out so I couldn't tell what went where. I'm hoping you guys would know. I looked at the download from the manual but it didn't seem right and kind of hard to tell how it sets on the end of the unit inside the fork.
Thanks for the help
ghostler
Has liked: 2 times
Been liked: 10 times
Re: Front fork question
Post by ghostler »
It's been a while since I disassembled both forks and replaced the seal, dust cover and spring with Progressive Springs. I think the threaded end that you show was held in place at the bottom of the strut by a single Allen socket head bolt in the center bottom of the strut.
The manual, Page 12-7 shows a Front Fork Cylinder Removal drawing.
Front Fork Cylinder Removal Diagram
The following is from my parts manual, Page 65 for the 2001 (B15) model. As far as I know, the parts are the same for years 1987 to 2003.
Front Fork Parts Diagram
Front Fork Parts Descriptions
Hopefully these will give you a clue onto what parts go where and how they interface. For easier viewing, you may want to right click after opening the attachment, and do a save image as to your hard disk. Then use your photo viewer to zoom in for a better look.
These users liked ghostler's post:
Hillbilly (Wed May 04, 2022 11:42 pm) • Nails (Thu May 05, 2022 4:04 pm)
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
Has liked: 107 times
Been liked: 277 times
This parts illustration from a 1987 catalog has a good view of the "hat shaped" shouldered washer and spring orientation.
https://www.partzilla.com/catalog/kawas ... front-fork
Been liked: 104 times
Here is a good video instruction.
Hillbilly
2021 versys
99 KLR650
Has liked: 27 times
Post by Hillbilly »
Thanks everyone, I knew I could count on you :thmup:
Hillbilly
2021 versys
99 KLR650
Has liked: 27 times
Post by Hillbilly »
Voykimmer,I didn't get the link to the video you suggested
Could you try again... I would like to see it. Thanks
It’s not a link it’s a file that won’t upload. It’s a video of Carl Leo doing a demonstration at the Santa Fe Rally. Not sure why it doesn’t upload. Probably to big of a file size.
Bonnie and Clyde
2007 KTM Super Enduro 950
2019 KTM xcw 300 TPI
Has liked: 189 times
Been liked: 50 times
Post by Bonnie and Clyde »
Out of curiosity can you remove the forks without taking the fairing off? I know the manual says to take the fairing off. I was hoping to just take the front wheel and fender?
Been liked: 82 times
Short answer YES.
Bonnie and Clyde (Fri May 06, 2022 2:52 am)
Has liked: 228 times
Been liked: 602 times
But after the 73rd time or so, the fairing practically jumps off anyway. ;-)
Nails (Fri May 06, 2022 2:22 pm)
Bonnie and Clyde
HMB Don wrote: Thu May 05, 2022 10:08 pm Short answer YES.
But the long answer is?
Has liked: 481 times
Been liked: 436 times
Bonnie and Clyde wrote: Fri May 06, 2022 2:48 pm
Still yes. No need to take the fairing off at all. I think maybe the service manual's recommendation to remove the fairing for some procedures is to keep from potentially damaging the fairing rather than it actually being in the way.
Bonnie and Clyde (Sat May 07, 2022 4:52 pm)
South Jersey Retreads
Patriot Guard Riders
Warriors Watch Riders
Bonnie and Clyde
GrandpaDenny wrote: Sat May 07, 2022 4:31 pm
It looks like the triple tree bolts are easy enough to access with the fairing in place. I was unsure about the suspension air tube thingy mentioned in the manual. Thanks for the response
Bonnie and Clyde wrote: Sat May 07, 2022 5:01 pm It looks like the triple tree bolts are easy enough to access with the fairing in place. I was unsure about the suspension air tube thingy mentioned in the manual. Thanks for the response
Do you really even have to remove the fork tubes for the work you plan?
Bonnie and Clyde
Nails wrote: Sat May 07, 2022 8:24 pm
Doing fork seals
Bonnie and Clyde wrote: Sun May 08, 2022 4:05 pm Doing fork seals
I have a good local independent shop and just took my forks off the bike, rounded up the parts, and took them down for Progressives, bushings, and seals. I didn't feel like messing with it when they have the right setup, and I don't mind throwing some work their way. So I don't really know what I'm talking about here, but I believe you can get the fork legs off and all disassembled without taking the tubes out of the triple clamps. Barry uses long clamps that fit right down through the fairing to pull his springs and change the oil. (That's on this fall's maintenance list.)
Bonnie and Clyde (Mon May 09, 2022 4:53 pm)
Bonnie and Clyde
Nails wrote: Mon May 09, 2022 4:39 pm
Leaving the tubes in the triples would be slick thanks
Heavy Armor
Has liked: 10 times
Been liked: 25 times
Post by Heavy Armor »
I'm hoping to get my forks off without removing the fairing also, and take them to a shop for rebuilding and a progressive spring upgrade. I did it myself on my Triumph, and what a mess. I have no desire to tackle that again. 😅
The air tube stays in place, there are collars that go around the fork. When pulling the forks, you have to hold on to the air tube collars to keep from pulling them down and breaking them. This is what makes a second person handy when pulling (and reinstalling) forks - someone to hold the tubes.
