I know my 93 runs. I have much of it disassembled. I am ging to get new carbs from carl leo. And cavles. But my front brake and clutch lever are limp.Multtiple questions:
1. when I have dealt with this on multiple other ujms I had to bleed the lines like crazy, I bought a mightyvac, had little success. Whether it was at the clutch, the brake front and rear, or a slave cylinder. Burping at the banjo worked on a stubborn 1500 suzuki. Is there a secret to doing this better. On a xj 650 the calpiers wouldnt budge, I had to rebuild the master cylinder, emery cloth the bore,one piston was so stuck I tried compressed air on the bleeder screw, finally got it out using grease gun, brake line plugged with a bolt I got at ace. I concur somethimes its justbetter to buy replacement cylinders. All that having been said, what do yall use for cleaning parts. I had a gallon of cleaner that was $50 but didnt work better than apple cider vinegar. Brake cleaner on the brakes? I will not venture out of my yard until I get the brakes 100%. Thabk you for the input. When yall see what I am doing to this bike you will say how sacrilege is that bike. Basically its more of an eddie lawson, kz 1200 bike I am shooting for.
brake questions, cleaning parts question
- Been liked: 235 times
Re: brake questions, cleaning parts question
You can order one-way SpeedBleeder valves: bleeding is a one-man job, opening the one-way valve, at the bottom caliper, you pump the lever, pushing brake fluid out the bottom. Only thing I have against SpeedBleeder valves, is they push the air bubbles downward, against their natural movement upwards. Be sure to keep plenty of fresh Brake Fluid in the reservoir, as you pump it out the bottom of the line, to avoid introducing more air into the system!
You can also reverse-bleed them, pushing fresh fluid up the line, to the reservoir, which is where the bubbles want to go already. Cheers!
