Clutch slip?
- AHOY
- 1
2007 Buell XB12R Firebolt
2009 Kawasaki Versys
2007 Kawasaki KLR650 (sold) - Has liked: 3 times
Clutch slip?
New member, new to me bike. If I'm in third or fourth gear and close the throttle, then hammer it around 3500 or 4000rpm, it seems like the revs go up a hair faster than the bike itself. I also cannot shift very fast. Is this normal, or indictive of a problem? I changed the oil with Rotella T4 the other day.
- Has liked: 902 times
- Been liked: 316 times
Re: Clutch slip?
It sounds like you may have sludge in you clutch master cylinder.
I recommend flushing the fluid,making sure both holes in the master cylinder are clean.
Make sure your fairing is covered with a plastic sheet,so when you spill brake fluid in it,you don't melt it.
You may also have broken spider springs in you clutch.
You can find these items discussed on this forum.
Let us know what you find.
- AHOY (Thu Nov 16, 2023 1:16 pm)
- Has liked: 505 times
Re: Clutch slip?
Up in the top right corner of the page.
