front brake light switch
- Current bike(s): 1996 voyager
looking for the front brake light switch for my 96 voyager all i can find is the cruies cancel are they the same switch or different and if different where is it and wee can i find one
- Has liked: 119 times
Re: front brake light switch
Front brake switch on 1987 and later models does also contain the cancel switch for the cruise control built into the same plastic housing as one unit with 2 plastic push probes on the front and 4 electrical terminals on the rear of the switch housing.
It is illustrated on the Front Master Cylinder parts diagram.
Apparently this switch is still a stocking item from Kawasaki, or any of the online part suppliers.
- Has liked: 505 times
I had a lot of trouble finding the correct switch for Gertrude. Then I discovered a hole in the bottom of the switch that's just perfect for squirting contact cleaner into. Voila, switch works again. I like free fixes.
- Stew (Tue Apr 16, 2024 10:44 am) • triton28 (Tue Apr 16, 2024 1:56 pm) • cushman eagle (Tue Apr 16, 2024 7:07 pm)
- Rating: 33.33%
