strong exhaust smell
4redjf
Has liked: 70 times
Post by 4redjf »
Got a question about the strong exhaust smell when the bike is freshly started and idling for at least 5 minutes.
No smoke, choke not on. Starts very fast, idles fine, all fluids are fine. exhaust is quiet doesnt sound like holes in it.
Its outside in the carport but if it was inside a garage it would be too strong of a smell.
I've not had it or drove it enough to figure it out yet.
109k miles , maybe the exhaust??
Has liked: 228 times
Been liked: 602 times
Re: strong exhaust smell
Too much choke?
Pilot jets too rich?
4redjf
Has liked: 70 times
Post by 4redjf »
wonder if i could run some carburetor cleaner in the fuel to clean the jets and carbs out.
It starts too good, runs smooth, idles fine.. so I'm hesitant to mess with the Carbs at this point.
I did notice that the rubber boot on the gear leakage is rubbing against the exhaust. But the smell isn't rubber burning.
Still doing more investigating.
Appreciate the input.
Has liked: 105 times
Been liked: 272 times
Check the free play of the moveable starter rail on # 4 carburetor. When the starter/choke lever is OFF there should be 1-3mm of free play in the cable, 3/64" - 1/8" for imperial measure.
Sometimes these are set too tight which can lead to an over rich mixture.
if it idles fine then the jets are not blocked.
Just a thought,
4redjf (Mon Jun 24, 2024 10:28 am)
Has liked: 851 times
Is it possible you have a small fuel leak you are smelling,or a misfire that is exhausting unburned fuel? :hmm:
Has liked: 83 times
Jeff/original poster said it was an exhaust smell not a fuel smell. :hmm:
Maybe a bad exhaust gasket somewhere.
4redjf (Mon Jun 24, 2024 3:30 pm)
4redjf
Has liked: 70 times
Post by 4redjf »
update on exhaust smell.
after riding it yesterday 50mi for test ride for other things, when i stopped in the ride, i didn't smell it.
and after i was home and working on it again, the smell wasn't as strong.
Maybe since it hasnt been ridden since i got it, the carbs exhaust and engine needed everthing burned out. hoping...
4redjf wrote: Mon Jun 24, 2024 3:33 pm Maybe since it hasnt been ridden since i got it, the carbs exhaust and engine needed everthing burned out.
Or skanky gas refreshed.
4redjf (Mon Jun 24, 2024 8:27 pm)
