Temp gauge sluggish/twitchy even with new ground?
Heavy Armor
Has liked: 10 times
Been liked: 21 times
Post by Heavy Armor »
So my temp gauge will gradually creep up to the warm mark, but even on a hot day in the 90's will not climb any higher. It also has a bad habit of wiggling, ticking, and sometimes diving to zero. The old negative wire seemed to have good connection, but just to be safe I replaced it with a brand new ground tied directly to the battery. Made sure the positive terminal was clean. No change, still slow and twitchy. What do you think could be causing this? Just a bad sending unit?
Has liked: 840 times
Been liked: 283 times
Re: Temp gauge sluggish/twitchy even with new ground?
It could be a bad connection anywhere from the sending unit through the harness to the guage. :hmm:
Do you have a service manual with which you could follow the schematic? :thmup:
There is a site on this forum from which you can download one if you have non :woohoo:
4
Has liked: 464 times
Been liked: 426 times
It's in my .sig below
South Jersey Retreads
Patriot Guard Riders
Warriors Watch Riders
