Ball and hitch
Ball and hitch
Do you guys ever use grease or Never Seize or slip plate on the inside of the tongue of your trailer hitch to keep it moving smooth? I know on a semi that you grease the plate for the trailer but I didn't know if it would make a difference on a small trailer.
- MTN99
Re: Ball and hitch
Charlie,
I use a little WD40 on the hitch ball to keep the rust off nothing else.
Now if it was a swivel hitch things might be different, but then I think I would use graphite not grease, molyplate or anything that might collect dirt.
Now Retired
Tony & Gail
Grass Valley Ca.
Tony & Gail
Grass Valley Ca.
- Me Again
- Been liked: 262 times
Re: Ball and hitch
Your really not supposed to put anything on the ball or in the hitch.
If it makes the hitch move easier it may allow it to pop off.
That being said.Make sure the mechanisms are clean and fit snuggly on the ball without binding.
This will eliminate any unwanted noises and keep your trailer trailing.
Putting a cover on the ball is probably better than polishing the chrome although the polish looks better.
- Nathan (South Carolina)
Re: Ball and hitch
I use a thin film of vasoline on the hitch ball to reduce friction from the ball and a dry trailer tongue. I started doing this after hearing a groan through turns while pulling my trailer several years ago. My tongue is really snug on the ball which probably causes friction from the two dry surfaces rubbing against each other. I place a thin film of vaseline at the top and sides of the ball. The vaseline is easy to wipe off after removing the trailer and also protects the ball. My ball is 8 years old with over 10 thousand miles of towing on it, so the wear on the ball could also be something to consider. I read in a motorcycle trailer towing tips article last week (I can't remember which site it was on) that recommended putting a coat of vasoline on the ball of the hitch.
Lone Eagle
2001 Kawasaki Voyager XII
- Chris near Kansas City
Re: Ball and hitch
I have seen people on the Motorcycle Trailer Towing forum talk about putting a piece of wax paper on the ball.
If you're going to use grease, just a little dab will do ya. I also bring a few paper towels or a rag, so that I can clean the ball after detaching the trailer once we arrive at the destination. You don't want to brush up against the greasy ball with your shin.
- Rusty - SC Iowa
Re: Ball and hitch
Whenever I have encountered a trailer hitch ball by accident, I didn't just brush up against it. Afterwards I was either on the ground or hopping around on one foot, where I was usually and a little grease wasn't even in the equation of what I was worrying about.Chris near Kansas City wrote: You don't want to brush up against the greasy ball with your shin.
I have trailered everything from little 8' trailers up to 35' goosenecks and fifth wheels, and have always greased the ball - except once. When we moved from Anchorage to here I pulled a 22' enclosed trailer and forgot to grease a brand new ball. After almost 3,000 miles and only 90 miles from home the trailer departed from the tow vehicle. After getting stopped and peeling my wife from the roof of the cab, I found the ball extremely worn. Needless to say I have never forgotten to grease the ball since.
Still plowin.
Re: Ball and hitch
Well, there are "encounters", and then there are "brushes". I'd rather have a brush with a skunk than an encounter with it, LOL. Now, combing a skunk, I'd have to think about that.Rusty - SC Iowa wrote:Whenever I have encountered a trailer hitch ball by accident, I didn't just brush up against it.
- Rusty - SC Iowa
Re: Ball and hitch
I have had both a brush and an encounter with those cute little fury things, and both times I was not welcome in the house. I guess for me there is no difference between the two.Chris near Kansas City wrote:Well, there are "encounters", and then there are "brushes". I'd rather have a brush with a skunk than an encounter with it, LOL. Now, combing a skunk, I'd have to think about that.
Still plowin.
Re: Ball and hitch
I have had neither, a brush, nor an encounter with Nicole Kidman. I can tell you, there is definitely, a difference between the two. Either way, I too, would not be allowed in the house.
