Cam Chain Tensioner Leak
Bill52
Post by Bill52 »
Does anyone know if the cam chain tensioner assembly can be removed without having to redo the cam timing. It appears that the leak I fixed by slapping gasket goop around it is starting again, so it appears I will have to remove it. I have done this on a Vulcan but am not sure about the voyager,Carl Leo, any tips?
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Re: Cam Chain Tensioner Leak
Post by carl leo »
the tensioner can be removed without disturbing the cam timing, once removed do not turn the engine over. the tensioner is sealed with an O ring. be sure to reload the tensioner assy when you reinstall it.
. :hpdc:
Bill52
Post by Bill52 »
One last question can it come out without removing the engine from the frame or removing the carbs? It looks like I can get the bolts off just not sure how much room I need to remove it.
carl leo wrote:the tensioner can be removed without disturbing the cam timing, once removed do not turn the engine over. the tensioner is sealed with an O ring. be sure to reload the tensioner assy when you reinstall it.
. :hpdc:
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
the engine does not need to be removed, i take the carbs off to give enough room to reload the assy on reassembly.
:hpdc:
Littlebeaver
Post by Littlebeaver »
Is there a how too's on this subject or a video,,, are there photo's How do you reload it,, what's the procedure for the aftermarket tensioner ? I am not having any rattling or issues I just like to know. Anyone put the aftermarket tensioner on their bike? :shock: I understand the stock oem one is self adjusting but how does one adjust the aftermarket one..?
Littlebeaver
I figured it out....
wmeier
Current bike(s): 2003 Kawasaki Voyager
Post by wmeier »
I have had what I thought was a valve noise, come and go. An experienced motorcycle mechanic heard it once and said that's your "timing chain tensioner". I assume the cam chain tensioner is the same thing. I am interested in more info on this. Do you think this is something that would "rattle" some of the time and not others? I can go 500miles with no noise, run 100 with noise, then 500 again with none.
Wayne Meier
Cochrane, Alberta
Canada
2003 XII
Rushnar
6
Current bike(s): 88 voyager 12
Post by Rushnar »
I have cam chain noise all the time..my mechanic is very very experienced..he said it's common..no big deal..ride it..
