My Light Bar
Dean
My Light Bar
Post by Dean »
A lot of people laugh when I tell them about my light bar, but I don’t care. It works, looks good and adds strength to the crash bars. After looking around for a factory one or an after market one – I decided to make my own. I do not remember the details as far as length, width and things like that, but this is basically what I did.
First I found a quality chrome towel bar (like the ones you see in bathrooms and such - see your laughing already) that was the same as the outside width of the crash bars. I cut it down to just a shade over the length of the width between crash bar ends. I found a nice steel pipe that was about the width of the inside of the towel bar. I cut it to length so that it would end up stopping up against the curve of the crash bar on both sides. I did end up grinding it down ( no lathe available ) to make it thinner so I could slide it into the crash bar ends and the towel bar. I painted it with a good spray can of enamel paint, so it wouldn’t rust over night. Then I just loosened up the crash bars so I could get the “light bar” in between and tightened them up again. Cheap to make, looks good ( even after about 3 years) and strong as a rock. I drilled and tapped the bar and pipe so I could attach my extra lights.
The End.
Take Care and be SAFE
Dean in WI.
'89 XII
'00 GL1500
kenquinn
Re: My Light Bar
Post by kenquinn »
Dean,
Sounds interesting. I'd like to see a few photos.
kenquinn
flip18436572
Re: My Light Bar
Post by flip18436572 »
Do you have some pictures?
If you can't post them up, email them to me and I can post them up.
Has liked: 95 times
Been liked: 155 times
Re: My Light Bar
Hey Dean, from what I see and think ........ no ones laughing. As a matter of fact I think a few others have come up with similar work-arounds for certain areas of concern/interest. A big plus to this forum is cost savings ideas that many come up with, so if some laugh at it let them. You can laugh too, the whole way to the bank $ !
:thmup: Great idea!
Dean
Re: My Light Bar
Post by Dean »
I will take some pic's and post as soon as I can.
Dean in WI.
'89 XII
'00 GL1500
tregal16
Re: My Light Bar
Post by tregal16 »
I am not laughing, as a matter of fact, I have been working on something like that myself. I just have to go get the chrome bar and make it. Nothing wrong with being frugal :thmup:
Re: My Light Bar
As long as the bike doesn't end up looking like it was cobbled together by Jethro Boudine, I'm fine with it. :gig:
Been liked: 107 times
Re: My Light Bar
I did the same thing a number of years ago only I found a towel bar that fit inside the crash bars. I cut it to length to the curves on each crash bar and bolted back up. Looks like solid crome all the way across and strong to. Accidentilly laid my bike over hard and it did not budge or bend the bars. Did this before I had it and bent the crash bar on the right side and cracked it so had to buy a new one.
Re: My Light Bar
Kim it would be great if you could post a picture or two of it. I'd like to make such a bar sometime in the future. The light bars I've found on Ebay are bidding up in the $200 range.
Re: My Light Bar
I will send them to Gary so he can post them for me. I don't know how.
Kim
Rhinestone Kawboy
1970 Honda CL350 Scrambler
1977 Carabela Marquesa 125 MX
Re: My Light Bar
Post by Rhinestone Kawboy »
Ok, here they are: (Kim- there is directions in the announcement section of most forums on how to post pictures in them).
I might add, that I seen that Marvellas had an accessory light bar available at the Rally. It was quite inexpensive and looked good. The last I looked, it was not on Marvellas's website, so you might want to contact them and inquire.
http://www.marvellas.com
Iron Butt Member #47339
Re: My Light Bar
Those pictures look great. I went to Marvella's site and nowhere on there could I locate a light bar though...
flip18436572
Re: My Light Bar
That is why Gary said to contact them, because he did not see it on their website.
Mike in Pekin , Il
Re: My Light Bar
Post by Mike in Pekin , Il »
who cares if it works for you and you like it. I saw a voyager today the gentlman had used cb antenna mount brackest to install his passing lamps. cheap, looks good, won't rust. whatever it takes.
Ride Safe and Ride Long,
Mike in Pekin, IL
tregal16
Re: My Light Bar
Post by tregal16 »
Over the weekend I finally got out to look for chrome "towel bars". I went to the hardware store, they sold Safety+First grab bars. I ended up buying at Ollie's (Discount store) for $10.00 it is 7/8" OD which fits exactly inside the factory crash bars, it was 24 inches long, I ended up cutting the bar down to about 21 inches. My thoughts are I am going to drill a hole and bolt it. However I imagine you could leave it the 24 inches and would be ok. I will have to get some pics and I will post them if anyone is interested.
flip18436572
Re: My Light Bar
What about drilling holes on the back side and just using pop rivets that wouldn't be seen by most people. They are easy to drill out if you have to replace the bar for some reason.
tregal16
Re: My Light Bar
Post by tregal16 »
I didn't think about that. That is a good idea.
Thanks, I will think about that.
