Moly in the rear drive?
- Current bike(s): 1982 Moto Guzzi V1000G5
1980 Yamaha XS850 - Has liked: 0
Does anyone use a moly additive in their rear drive? It is recommended in my Guzzis where I have used it for many years. I can't see a problem adding a little to the the rear drive on the Voyager. The rear drive's small capacity is the only thing giving me pause. Any thoughts or prior experience is welcome.
- David (N. Alabama)
Re: Moly in the rear drive?
I only put in what Carl Leo recommends. He ain't steered me wrong yet. :-)
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
I just use 90 wt synthetic gear lube in my rear drive, never had a problem, I don't think graphite is necessary. Be sure you don't have the fill level above 1/4" below the fill hole though.
Iron Butt Member #47339
- ksawatsky
How often do you all change your gear oil?
IBA #487
2001 BMW K1200LT
IBA #487
2001 BMW K1200LT
I do it first thing every spring (5-7k miles)ksawatsky wrote:How often do you all change your gear oil?
- Nathan (South Carolina)
The maintenance manual states around 18,000 miles for final gear oil change. There is really no reason to change it any earlier than that in my opinion. I usually change mine around 20,000 miles. How often do you change it in your car or truck? They use the same oil.
Lone Eagle
2001 Kawasaki Voyager XII
- doug of so fla
I change at around 40 to 50K miles. Manual says 30,000KM, Change more often on higher mileage machines, Check every 10,000mi for level, smell and clarity. Use a good quality lube. Make sure you have a vent hole on the inside of rear end at top. Do not over fill, 1/4" to 3/8" from fill plug thread to oil level. Never had a problem, knock on wood!!!
- Chris near Kansas City
Well, actually, filling the final drive to 1/4" below what's recommended in the manual is a very well documented trade secret when servicing the Voyager XII. There are many people that have filled their machine to the "proper" level and had a leak afterwards due to the increased pressure from within the final drive when hot. Filling the unit to 1/4" below the fill plug threads, usually takes care of the problem.
Especially if you are towing a trailer, or running at max or over the weight rating for the bike and doing high speed with hills. That will really heat up the rear drive.Chris near Kansas City wrote:Well, actually, filling the final drive to 1/4" below what's recommended in the manual is a very well documented trade secret when servicing the Voyager XII. There are many people that have filled their machine to the "proper" level and had a leak afterwards due to the increased pressure from within the final drive when hot. Filling the unit to 1/4" below the fill plug threads, usually takes care of the problem.
Peeled the paint on the pumkin on a truck one time pulling a heavy load up hill at interstate speeds.
Thanks guys, I have no doubt that your recommendations are completely sufficient, but it has been a spring ritual for me to change all fluids in all my bikes for 28 years now. I am sure it is overkill but it makes me happy.Aufgeblassen wrote:I think the book says change every 40,000 miles.JosephH1 wrote:I do it first thing every spring (5-7k miles)ksawatsky wrote:How often do you all change your gear oil?
I am sure the moly is overkill too, but I doubt it will hurt anything.
