Self Cancelling Turn signals
- Current bike(s): Kawasaki Voyager XII '94
This topic has probably been covered in here somewhere, but I cannot find an answer yet. So. . . . here's question; my XII's self-cancelling turn signals don't cancel anymore. Could you's guide me in some areas to look. Thanks!
Dennie in the UP of MI
'94 XII
'94 XII
- vxiirider
- Tourer
- Has liked: 96 times
- Been liked: 32 times
Re: Self Cancelling Turn signals
Try spraying the turn signal switch with electrical contact cleaner or WD 40 and working the switch back and forth to clean the contacts.
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
Charlotte, Michigan
- biggersm
2000 Voyager XII
1998 Suzuki Intruder 1500
1989 Honda PC 800
1982 Yamaha Maxim 750
1993 Yamaha Seca 600
1981 Yamaha XV920 (part 2)
The same thing happened to us but I consider loosing the self canceling feature to be a good thing (as long as the indicators lights in the dash still work). Who uses turn signals in Florida anyway?
Since you like that feature let's ask how is your speedometer, odometer, cruise control and automatic volume control (these features did not change for us when we lost the self canceling feature). It could be a speedometer cable about to go or the gear wheel down on the front wheel.
Other than that check all the fuses.
Mike and Marcia Biggerstaff
Melbourne FL
Melbourne FL
could be as easy as cleaning the plug at the canceling unit. after receiving the proper amount of pulses from the speedometer head the unit activates a solenoid and plunger to release the turn button. If your cruise/audio increase/and speedometer work that rules out the signal is not working, check the plug for corrosion, its a bit of time to get too. Then it would be either a bad cancel unit or the solenoid/ or wiring is the culprit. ekap1200
- Me Again
- Been liked: 272 times
.vxiirider wrote:Try spraying the turn signal switch with electrical contact cleaner or WD 40 and working the switch back and forth to clean the contacts.
I agree ,but,don't get carried away with the oil or you may find you cannot get it to stay on at all
Thanks for the responses. Are you's suggesting taking the left switch assy. apart (some screws underneath, etc.) checking and lubricating the connections or just carefully spraying the outside of the switch?
'94 XII
'94 XII
Not me, before I would take it apart I would see if at the canceling unit I have power when the signal switch is activated left or right at the WHITE/RED wire. If the contacts in the switch are dirty work them left/right. Does the bike reside outside or in a garage ? Have you ridden allot in the rain? A 1994, chances are the plug to the canceling unit has never ever been pulled apart . Anyway that's where I would start, at the plug and from there test with a ohm-meter for continuity to the solenoid from the plug , and a ground signal from the reed switch in the speedo-head.
- Me Again
If I remember correctly the thumb knob covers the entire slot ,so you have to remove the knob (small screw under knob) .put a very small amount of your favorite penetrating oil in the slot,work it back and forth a couple of times ,then go for a ride and see if it works.hissondk wrote:Thanks for the responses. Are you's suggesting taking the left switch assy. apart (some screws underneath, etc.) checking and lubricating the connections or just carefully spraying the outside of the switch?
I agree with Ekap1200 that before you start taking it apart you should check to make sure it is electronically functional,although it is hard to test the shut off mechanism unless you turn the front wheel .
One way to check it (after checking the wires ) is to go for a ride ,turn the blinker on and put your thumb against the switch,you should be able to feel if is attempting to turn off.
Never start by taking something apart.
Have a little experience with my '86 XII. To start with, is your battery fully charged - signals won't cancel with a low battery - sometimes this is your first tip that your charging system is faulty. The next thing is to split the control assembly on the left handlebar - have your contact cleaner ready with the red tube attached and spray the turn-signal-switch with the cleaner and then put back together; work the switch a couple times, then start bike and test. This worked for me a couple years ago and I didn't use any lubricant (i.e. WD-40) and its still working to this day. Good luck and "enjoy the ride".
Enjoy the ride !!!
- Ohio Mike
Is there one solenoid that gets fired to cancel the signal or two? My left signal self cancels MOST of the time but the right signal has NEVER canceled since I bought the bike used about 15k miles ago. If all the work is done by a single solenoid, I would think the right signal would cancel at least once in a while. Previous owner painted the bike so it may have been torn completely down. Maybe they broke something on the reinstall?
Thanks,
Ohio Mike
Thanks,
Ohio Mike
Mike in Celina
- metric
Last week I lost the "self canceling turn signal" too and I think it's a good thing, I usual signal two times because
was so short so now I just have to remember to switch off after the turn...
02VoyagerXII AVA#5443
- Chris near Kansas City
Yep. Mine quit too. Pretty sure it died on the way back from Degray Lake. I couldn't be happier. Sort of.
- suzib6sw
- Tourer
Another possible reason.. the signal from the speed sensor is not getting to the SC unit.. Easily diagnosed as the Radio volume will not adjust automatically with speed increase/decrease and Cruise Control (Post 86) will not engage correctly.
If the pickup is working but not sending 4 pulses per rev, then the time for the SC unit to work and the speed range and volume speed adjust will all be off too ..
Normally, Ide check the solenoid and spray with WD first..
THEN pull the headlight, look at the radio for the blue and yellow pair of wires, pull the connector and look for 8 volts at both ends..
Pete
Pete
Pete
1986 Voyager XII
1986 Voyager XII
- Muleears
I hate to resurrect an ancient thread but I now have a problem with my self canceling signals. They had worked most of the time but I wasn't happy with "most" I wanted all! So in doing my due diligence I found this thread. I promptly split the control on the handlebar and sprayed the switch with WD40 and worked it several times. Well, now I have it all.... They DON'T work at ALL! My volume works properly, didn't try the cruise though. I don't know what I did but obviously it was something... I should clarify, the turn signals work properly, they just don't cancel at all. Its getting dark so any further repair attempts will have to wait for daylight but what could I have done? I'm sure I put it back together correctly. I didn't have any contact cleaner or dielectric grease. I'll get some tomorrow and give that a try. Failing that, I could take the contact out and buff it with a little fine sandpaper and reassemble. Anyone have any suggestions??? This is what I get for trying to solve my own problems... more problemssuzib6sw wrote:Another possible reason.. the signal from the speed sensor is not getting to the SC unit.. Easily diagnosed as the Radio volume will not adjust automatically with speed increase/decrease and Cruise Control (Post 86) will not engage correctly.
Pete
Cal
'02 Voyager XII 22K miles
Hampton Roads, VA
Hampton Roads, VA
- Been liked: 249 times
Electronic contact cleaner leaves behind zero deposits. It used to be called, Tuner Cleaner, used on TV tuner switches. It should remove the WD-40 residue, while leaving everything squeaky clean, no residue.
I would not recommend disassembly of the switch, nor sanding the contacts. They are quite small, delicate, and challenging to work with. It is not like you can pick up a replacement easily, or cheaply. Try the Contact Cleaner, first, and be patient. Soak it, work the switch back and forth, to ensure the contacts are rubbed while wet with cleaner. Best of luck -- I will be pursuing this soon, same issue, didn't know how to fix, until now. Cheers!
- Muleears
Thanks SgtSlag. I will give that a try.
Cal
Hampton Roads, VA
Hampton Roads, VA
If your turn signals are flashing its not the switch contacts. That is totally seperate from the cancel circuit. The cancel circuit is a soleniod plunger that releases the switch. Controled by the turn signal cancel module and could be just a bad connection at that units plug or an open in the soleniod coil. Or an open in the wiring or bad module. Or the plunger is sticking, which since you said it occasionally works is the most likely.
- Muleears
Gene,ekap1200 wrote: Or the plunger is sticking, which since you said it occasionally works is the most likely.
They were occasionally canceling before I "fixed" them.
Cal
Hampton Roads, VA
Hampton Roads, VA
- chevyman1
- Board Member
- Been liked: 16 times
You have to take the switch apart and clean out all the dirt and grime then put some dielectric grease on it and it should work better then new.
Be careful when you take it apart the parts are small but you should not have a problem.
- Muleears
Thanks Chevyman1, I didn't see any grime the first time I had it apart, maybe I didn't go far enough. If I have time I'll take a look today.chevyman1 wrote:You have to take the switch apart and clean out all the dirt and grime then put some dielectric grease on it and it should work better then new.
Cal
Hampton Roads, VA
Hampton Roads, VA
