right side upper hose on raditor help
chris.trombley
Current bike(s): 1993 kawasaki zg1200/b7 voyager
Post by chris.trombley »
last week i did all the things i needed to tighten frame bolts changed the cluch flulid topped off raditor went for a ride all was good the next day i did a benifit ride 150 miles we got to the stopping point for the benifit and the right side upper hose let go so we temped it and i was able to get home. Well today i went and found the hoses to replace them i did both left and right sence i had it apart left side was weak in one spot good thing i did both got the right side back on and filled it with flulid hose is not leaking but the hard line going into the cylender has to leaking because i can't see and flulid comming from around the new hose. Is this a big job to fix or is there an o ring for the hard line? In the shop manual it looks like there is an o ring but i don't want to make it worse if not please advise thanks
Live life to the fullest and have fun you only get one chance
Chris north Ga
93 xll[ totaled]
99 Suzuki Intruder 1500 lc
Been liked: 82 times
Re: right side upper hose on raditor help
If you're talking about the water manofolds for the cylinder head. Then yes it's just an o-ring underneath. Good Luck
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Post by gearheadfla »
You may have moved them just a touch when replacing the hoses, try pushing then in a touch and it may stop, I replaced all my hoses when I did my make over, don't want to do that again anytime soon, what a pain in the :tho: :gig:
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
chris.trombley
if the o ring is bad and has to be relaced were do i get[ Mr Leo to the rescue?]
Chris north Ga
93 xll[ totaled]
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Mr. Leo or I would try to match one at a local auto parts store, NAPA is the best bet, just take the old one with you and let them know it's for coolant.
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
chris.trombley
thank you will do and let you know
Chris north Ga
93 xll[ totaled]
chris.trombley
got the leak fixed napa had the o ring and they gave it to me so no more leak now another problem has showed up it just doesn't run smooth not back firing or skipping but not 100% check all hoeses can't find any unhooked or pinched could the spark plug getting wet have anything to do with it its dry now and still not running right
Chris north Ga
93 xll[ totaled]
