alternator not alternating - or isn't it?
- richardb, austin
On my '94 V12 w 89k miles, I have 2 voltmeters & they both say that my alternator is intermittently not producing. I have checked using 2 different batteries and 2 different alternators - in all possible combination of battery and alternator and get the same result. Both alternators were rebuilt by A&M in Phoenix within the past 6 months. Now, I finally notice this: when I hit a big bump in the road sometimes the voltage drops & continues to get lower. but then, when I hit another bump, sometimes the voltage comes back. I now suspect a bad connection in the wiring coming from the alternator toward the rest of the bike. What say ye? Where exactly is the 3 pin connector where the red wires from the alternator become white wires to go on toward the main fuse? And in that continuing route to the main fuse, where exactly is the 10 pin connector where the alternator is white wire in and white wire out? Is that the biggest, white, Hitachi connector?
richardb, austin
__________________
__________________
- Been liked: 135 times
Re: alternator not alternating - or isn't it?
Pull the fake tank off and to the left of the fuse box you will see a single white wire (apx 10gauge ) . Check that out first. Its a starting point and subject to rain water when riding. Good luck. As you check all the plug connections it would be a good time to put some dielectric grease on the now cleaned connection. Sure does sound like something is opening up in the wiring somewhere. If its been going on for some time now, the connector that is the problem may show signs of getting hot and discolored. You haven't mentioned a dead battery condition, Make sure your add on voltmeter is not going kaput, or that its wiring isn't opening up. GET ER DONE, ridding season is upon us. Keep us informed were all happy to help. Gene Kap.
( ps. key switch harness has known issues, if still plastic tied to the frame tube. )
- richardb, austin
Thanks Gene. I've since cleaned & lubed and dielectric greased all the upfront connectors that I could reach - starting with the 3 each 3pins in the alternator wiring on the left side. No joy yet. Gonna try your suggested connector, then probably call Carl. Handlebar ties long ago removed.
richardb, austin
__________________
__________________
- Chris near Kansas City
That 3 wire connector where the red wires turn to white is behind the faux tank cover about where your left knee would sit.
Edit: It may be behind the chrome triangle cover, behind your knee.
