Running Poorly
Running Poorly
I have my 99' Voyager. It has been sitting awhile this winter, with periodic starts. When on full choke or a little off close it runs, if I open the choke it runs poorly, like it is starving for fuel. Just some questions. I have read about the points of the fuel pump needing cleaning, the fuel pump, the fuel filter. or possibly just old gasoline. I would like some input, would be appreciate.
David
David
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Re: Running Poorly
The first thing I would try is fresh gas and Seafoam, I bought a 01 that sit for God knows how long and it was missing on one cyl. unless it was on full choke, fresh gas and Seafoam has made it 95% better with just starting it, letting it run until the cooling fan turns on and shutting it down at a high RPM to "flood" the carbs and cyls. let sit and repeat again the next day, 3 days later it's not missing and will idle. My 01 is not ready to be ridden on the road yet so maybe riding your would help even more. I'm thinking the fuel pump would either work or not work, also check your fuel filter, if clogged that would starve it for gas. The choke on a XII don't really "choke" as we think, it enriches the fuel mixture to feed more fuel in.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
Re: Running Poorly
I have got the Seafoam will try it. What is the best way to drain the gas tank? Its one of the few things I have not messed with. Appreciate you help with this. I will try it tomorrow, need a little more warm weather, supposed to be warmer tomorrow and this weekend.gearheadfla wrote:The first thing I would try is fresh gas and Seafoam, I bought a 01 that sit for God knows how long and it was missing on one cyl. unless it was on full choke, fresh gas and Seafoam has made it 95% better with just starting it, letting it run until the cooling fan turns on and shutting it down at a high RPM to "flood" the carbs and cyls. let sit and repeat again the next day, 3 days later it's not missing and will idle. My 01 is not ready to be ridden on the road yet so maybe riding your would help even more. I'm thinking the fuel pump would either work or not work, also check your fuel filter, if clogged that would starve it for gas. The choke on a XII don't really "choke" as we think, it enriches the fuel mixture to feed more fuel in.
David
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Re: Running Poorly
I have never tried to figure out how to drain the tank but that's a good question and I'm sure someone here has done it. They will chime in and help. I will take a look at my parts bike, it's all stripped of the tupperware and the tank pretty mush exposed. But even though I am in Florida tonight it will be 38 degrees and that's COLD for us southern wimps, so I will look at that in a couple days.
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
01 XII-sold
07 Vulcan Nomad
- Been liked: 102 times
Re: Running Poorly
To change the fuel filter you have to take the fuel line from the tank off of one side of the filter. If you don't pinch the line preventing fuel from leaking it will empty the tank.
- Been liked: 234 times
Re: Running Poorly
I would try the SeaFoam, first, without draining the gas tank. SeaFoam will absorb water, to a point, as well as dissolving minor varnish deposits. Start simple, and work towards the complex, only after the simple stuff fails to fix the issue. If it runs better with SeaFoam, try running the bike until the tank is pretty drained, then fill it with gasoline, and add more SeaFoam, following directions, to absorb any water left, as well as dissolving more varnish (if any is left). After that, it may be time to drain the gas tank/remove and clean the carbs/whatever, if performance does not improve. Cheers!
Re: Running Poorly
You can always do like the old days with cars and syphon the gas out of the tank.
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
Re: Running Poorly
I love working on my bikes, with that said I still always try the simple stuff first to get out of the harder part. If that don't work then I have no problem diving in head first. Try the Seafoam and fresh gas and see what it does, go from there. Many years of stockcar racing taught me the K.I.S.S. method (Keep It Simple Stupid) and it saved me a lot of heartache and money once I started not re-engineering everything I broke.
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
01 XII-sold
07 Vulcan Nomad
Re: Running Poorly
Kim In Illinois wrote:To change the fuel filter you have to take the fuel line from the tank off of one side of the filter. If you don't pinch the line preventing fuel from leaking it will empty the tank.
Thanks for the tip. I thought taking it loose from the filter would drain it or most of it.
David
