Making Lower Fork Tubes Look Better
Own something other than a Voyager? This forum allows you to more easily find non-Voyager articles.
MalamuteMike
Current bike(s): 1998 Voyager
1995 Voyager Born 1995 Died 17 July 2011
1983 750 CSR
1987 750 Ninja, a 20+ year rebuild that will never get finished in my life time!!!
Post by MalamuteMike »
I have forks on our 1200 that had state decals on them and now they look like crap, I was wanting to know if anybody has fixed there fork tubes, I was thinking of maybe glass beading then clear them, need to find a clear that will stick, or does anybody have other ideas on fixing them.
You need to find humor in a train wreck!
And I have had to find humor in my/our train wrecks through life!!
bikerking.biz
1970 Honda CL 350
Re: Making Lower Fork Tubes Look Better
Post by bikerking.biz »
Remove the clear coating that comes stock on them. Some sand it off, others use paint remover. I would use a chemical remover. If there are any rough spots, sand them with about 220 or finer paper to smooth out, then use a finer grit i.e. 400 or 500, then just use metal polish (not chrome cleaner) and polish them to chrome like look. You will have to redo it occassionally, but it is easy once the clear coating from the factory is removed.
Biker King
http://www.bikerking.biz
David (N. Alabama)
2014 Triumph Trophy SE
Post by David (N. Alabama) »
I used to do this to all my 1970s motorcycles that I owned in the 1980s. I used steel wool and mothers polish
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Post by gearheadfla »
Here's the ones on my 88, I used aircraft stripper to remove the clear coat, then started with a bench buffer working to rubbing compound to wax, then use Liquid Diamond polish, I also stripped the rim with aircraft stripper and hand polished it, this pic shows water spots from mounting a new tire but you get the idea.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
MalamuteMike
1983 750 CSR
I had the forks rebuilt, so when I got them back I figured I would clean them up, I sanded them with 220 grit then 400 and finished with 800 grit, then took my adjustable speed buffer and alum. polish and after about a hour & a half to two hours they were finished and they look all nice & shiny now, Thanks for the ideas
Return to “All Other Brands General Forum”
