Voyager xii wont start when hot
johnhanley
Current bike(s): Kawasaki Voyager XII (1986)
Post by johnhanley »
Hi Everybody, i wonder if anyone can help with this?
i have an '86 Voyager xii which normally starts very easily. recently i noticed that if i have been out for a ride, stop for a short while & try to start up again the engine turns over ok but wont fire up! if i wait for 30mins then it restarts ok. any ideas what might be causing this? i'd appreciate any help. Thanks, John
Bruce in OK
Current bike(s): '01 VXII
'06 Vespa GTS 250
'02 Honda Elite 80
'99 Honda CB 250 Nighthawk
Re: Voyager xii wont start when hot
Post by Bruce in OK »
What kind of shape is your battery in?
Bruce in OK
Gator Mike
2002 Honda 750 ACE
1969 Honda 90
Post by Gator Mike »
This probably has nothing to do with your particular problem but does the ignitor have a part # that ends in 1179. If it does and the battery is low it can cause the engine to backfire breaking the starter chain. Very expensive to fix as the engine cases must be split. If that is the part # I would not start the engine again till it is changed. This was a problem only on the 86 & 87 as the ignitors were changed on the later models.............Gator Mike
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Post by gearheadfla »
Gator Mike wrote:This probably has nothing to do with your particular problem but does the ignitor have a part # that ends in 1179. If it does and the battery is low it can cause the engine to backfire breaking the starter chain. Very expensive to fix as the engine cases must be split. If that is the part # I would not start the engine again till it is changed. This was a problem only on the 86 & 87 as the ignitors were changed on the later models.............Gator Mike
And if needed, I have a spare updated one I would be willing to work out a deal on.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
Lucasind
and a bunch of parts !
Has liked: 203 times
Been liked: 72 times
Post by Lucasind »
....most likely ignition,, (igniter) problem.
johnhanley
Thanks for the comments i appreciate them.
the battery is well charged & in good condition.
i just heard from someone that it might be a problem with the coils? thoughts anyone?
Thanks again & Hello from Ireland!
