Thank you so much and I'm looking for to reading your replies. John
Here are a few pics of the lights I installed on my '91 V XII.Sarge1961 wrote:Ok guys I'm looking for additional lighting ideas for my 92 Voyager XII. I'm mainly looking for lights to mount to the light bar I found and bought. So if anyone out here has ideas could you please send them my way? Also if you would be so kind as to send a link or pictures of your lights and bike if you have the light bar also.
OK, here's one. I got it to work!Sarge1961 wrote:OldKawDrvr. I wanted to thank you but the links you sent didn't work so I was unable to view your pictures.
Here's a link to the lights. Not the seller I purchased from, but the same lights. Less than I paid too.Sarge1961 wrote:Looks real good do you remember where you found the lights and could you send me a link?
I mounted my lights up high because I didn't want them in the path of anything kicked up by the front wheel.SgtSlag wrote:Those are nice lights for night driving! Thanks for sharing.
The decision to make is whether you want driving lights for all the time, or high-powered lights to supplement your hi-beams. Or you could go with both.![]()
The lower wattage LED's can be used as 'on-all-the-time' running lights (what I did, for increased visibility; forms a triangle of lights, LED's low, and headlight high). The current draw on all of these is so low, you could run both, without straining your alternator/battery. Relays, for switched power, are the only way to go. I'd recommend a sub-fuse box to handle the extra circuits, and fuses needed. Most folks mount the sub-fuse box under the false gas tank, on the right side (perfect, open space for it). Cheers!
Lucasind wrote:GENE, If ur going to the rally, we should go for a evening/night ride....
One of the neatest organized rally rides we've been on, was the night ride in 2004 in Asheville, NC. on a section of the Blue Ridge Parkway. Pam and I were right in the middle with about 15 bikes in front and 15 bikes behind. Something cool seeing all those Voyager tail lights lit up!ekap1200 wrote:Tony, its been years since I have gone for a ride at night.
