reserve antifreeze tank removal
wmh9680
Current bike(s): 2002 Kawa Voyager
1996 Yamaha Virago 1100 Special
Post by wmh9680 »
Hello, haven't been here a while, long story, but today I was changing my antifreeze and I was wondering how to get the overflow/reserve tank out/off. I did it once before and it was a real pain to get it to come out. Thanks, Mike
OldKawDrvr
Current bike(s): 1978 Kawasaki KZ1000 Ltd
Re: reserve antifreeze tank removal
Post by OldKawDrvr »
There's a bolt and a bracket on the left end under the filler cap. Remove those and then pull straight out to the left. It's held by a pin in a grommet like the airbox covers and can be difficult to remove. Maybe you can reach in from the right and squirt some lube on the grommet with a long nozzle. The grommet is mounted on the fuel pump bracket. Good luck.
wmh9680
Post by wmh9680 »
Thanks, I took the bolt/bracket off but it just seemed to not fit out of the opening. Didn't remember about the grommet. I just siphoned out the old antifreeze. I didn't see an o-ring anywhere to check or replace but so far it isn't leaking. The next step is to check the spark plugs. Thanks again, Mike
MalamuteMike
Current bike(s): 1998 Voyager
1995 Voyager Born 1995 Died 17 July 2011
1983 750 CSR
1987 750 Ninja, a 20+ year rebuild that will never get finished in my life time!!!
Post by MalamuteMike »
wmh9680 wrote:Thanks, I took the bolt/bracket off but it just seemed to not fit out of the opening. Didn't remember about the grommet. I just siphoned out the old antifreeze. I didn't see an o-ring anywhere to check or replace but so far it isn't leaking. The next step is to check the spark plugs. Thanks again, Mike
Did you take the cover off that covers the hyd. clutch take the 4 bolts out and remove the cover and give it a good pull and it should come off
You need to find humor in a train wreck!
And I have had to find humor in my/our train wrecks through life!!
wmh9680
Post by wmh9680 »
I did take off 2 covers, one over the alternator and one below it with 4 bolts(it wasn't chrome but a metal finish). I think that is what you are talking about. Thanks, Mike
wmh9680
Post by wmh9680 »
Where is the grommet, on the bottom of the tank? Thanks, Mike
