Heel-Toe shifter
joerod777
Current bike(s): 2003 Voyager XII
Heel-Toe shifter
Post by joerod777 »
Available on ebay is a Voyager heel/toe shifter. I bought one and installed it today. Easy to install and works nicely. Here's the link on eBay:
http://www.ebay.com/itm/120899554605?ss ... 1439.l2649
JoeRod
jre258 in SoDak
Re: Heel-Toe shifter
Post by jre258 in SoDak »
I remember seeing a heel-toe shifter from someone else that was very similar to this one. Only it was made to use u-bolts to fasten to the stock shifter. No drilling required.
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Post by gearheadfla »
Now I need to do a heel toe on my XII, my Nomad has one so when I switch bikes back and forth I get really confused :bat: But come to think of it, it don't really take much to do that. :-O :gig:
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
biggersm
2000 Voyager XII
1998 Suzuki Intruder 1500
1989 Honda PC 800
1982 Yamaha Maxim 750
1993 Yamaha Seca 600
1981 Yamaha XV920 (part 2)
1981 Yamaha XV920 (part 1)
Post by biggersm »
I used to have a heel and toe shifter on an Intruder 1500 we used to have. It didn't take long to get used to it and it was certainly a good idea if you wanted to keep a shine on the toe of your left boot.
The shifting process can maybe one full second longer the more conventional shifting methods (as you line up you heel for the upshift). Unless you have a rather large flywheel to keep momentum between shifts it does noticeably slow you down which can annoy your riding buddies or potentially put you into an unsafe condition between you and the cage behind you.
I think heel toe shifting is a good idea for the 1700 but maybe not so much for a XII and anyone who rides sporty, shifts a lot, and wants lots of power at all times. Your results may vary.
Mike and Marcia Biggerstaff
Melbourne FL
Davew
Current bike(s): 03 Voyager XII
1976 Kaw. KZ900LTD
Post by Davew »
I have his type of heel shifter, this is the third one on my bike and by far the best.
I purchased mine thru Carl Leo who sent it out and had it chromed and picked up
chrome peg for it. It feels solid when shifting, and with the shifter cover on the stock
shifter it raises it so its easier to find with to toe for downshifts. Once you ride with
this one, well you'll see what I mean. :thmup: :thmup: :thmup:
David Wirtz
Summerville SC.
Past AVA board member
Palmetto Voyagers, AMA,SCRC, ROK
03 Voyager XII & Bushtec Trailer
Skibou
Post by Skibou »
I also bought one from Carl, and I'm happy with it. I got used to the heel and toe action on my Vulcan, and found I liked it better. Just a caution though, check the tightness of the bolts holding it to the original shifter occasionally. On a recent long trip, I found that the bolts had loosened, and tightening them at the side of the road took a while as the floorboards and shifter had to come off to get a good grip on the nuts.
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
just a tip. if you will drill and tap the center of the shift shaft to 6mm and put a large washer behind the bolt you put in the tapped hole it will prevent the lever from working loose..........carl
:hpdc:
