Help finding and repairing clutch fluid leak.
- Current bike(s): 95 Voyager 1200
2002 YZ 250
2007 CFR 250x - Has liked: 0
I was going to ride, but found my clutch was not operating because all the fluid was missing from the reservoir. Where is the best place to start to find my leak?
- bikerking.biz
Re: Help finding and repairing clutch fluid leak.
I would think just add some fluid in your reservoir, squeeze the lever a few times, and see where it might be leaking. Pull the left side access cover off of the engine so you can see the clutch bleed valve- maybe that loosened somehow.
Biker King
http://www.bikerking.biz
- debron
A similar thing happened to me last summer on my way to the rally in Kanab, Utah. I pulled in to Groveland, CA just outside Yosemite and each pull of the clutch gave less and less response. Pulled the top off the reservoir and it was empty. Filled it up but never found a leak. That was over 15,000 miles ago and still no leak and no more problem. I have no idea where the clutch fluid went.
- Current bike(s): 77 kz 1000
75 z1 900
77 kz 650
98 voyager - Location: Cypress, Texas
Baby powder works great for finding leaks. Clean the area off with carb cleaner and let it dry, sprinkle baby powder around the area you suspect and work the clutch, if there is anything you will see it right off the bat. Plus clean up is simple
77 LTD 1000
77 kz 650
75 z1 900
98 voyager xii
State Captain
Texas Patriot Guard Riders
77 kz 650
75 z1 900
98 voyager xii
State Captain
- Guru
76 kz900 LTD
spray powder deodorant works great and you can get in tight spaces with it.........
