Radiator fan switch
- doug of so fla
Re: Radiator fan switch
The sensor switch is on the bottom front kinda left side (sitting on MC) of radiator. You need to take off the radiator shroud and left lower fairing piece Right where the wire comes out of the sensor and makes a sharp turn is where it usually fails, you may be able to see bare wires right there if you look real close. To check to see if that switch is your problem right by the left horn the sensor has a connector just disconnect it and ground it to the frame and the fan should come on . If it does not then the fan itself may be bad , if it comes on that means that the sensor itself is bad.
