Went for a 200 miles ride on Saturday and by the time I got home the clutch was slipping very bad so today after work I open up the clutch and pieces of the leaf spring was foaling of the case , what size is the nut I have to remove to change the spring and I'm going to need a removal tool to hold the basket when I loose the nut? I check the friction plates and are in the specs...3.0 to 2.95 mm the 6 springs are under the specs and I'm going to change them...
I have 3 weeks to get everything done for the trip to NC.
Thanks... Mike
Broken leaf spring...
