Diverting radiator heat to legs
EZdriver
Post by EZdriver »
I installed a set of mini boards to my bike. When my legs are on them, I can feel some pretty intense heat (duh) from the deflector openings. I had a brainstorm thinking maybe some of that could be diverted aft and up in the winter for heating your lower extremities. It would require cutting a hole in the aft face of the lower cover and installing an eyeball type vent that could be rotated, directed, and closed off in the summer. Just wondering if anyone out there has done this? :hot:
2003 Victory V92TC (sold)
1970 Yamaha 400 Enduro
1969 Kawasaki 500 Mach III
1960 Cushman Scooter
Bill O
2003 1200 Voyager
Been liked: 6 times
Re: Diverting radiator heat to legs
Post by Bill O »
EZdriver wrote:I installed a set of mini boards to my bike. When my legs are on them, I can feel some pretty intense heat (duh) from the deflector openings. I had a brainstorm thinking maybe some of that could be diverted aft and up in the winter for heating your lower extremities. It would require cutting a hole in the aft face of the lower cover and installing an eyeball type vent that could be rotated, directed, and closed off in the summer. Just wondering if anyone out there has done this? :hot:
An old trick that proved to be very successful was to block the side gills of the fairing lowers, then remove the lower vent tubs from the fairing. Then you can regulate the engine heat through the lower vent louvers. This was usually only done in parts of the country where winter weather is light on snow, but cold for riding. A good temp modification for winter riding.
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
Chris near Kansas City
Bill O wrote:An old trick that proved to be very successful was to block the side gills of the fairing lowers, then remove the lower vent tubs from the fairing.
Bill O
Also, block the lower vent on the front.
EZdriver
Post by EZdriver »
That makes sense. Thanks!!
