hello all, i was out on a short ride this morning. when i came back pull in the driveway i noticed coolant leaking from under the reservoir tank.i looked at the tank to see if it was too full. no infact it was just above the low mark. but the leak looks like it is coming from under the tank. anyone have any ideas what it could be?? need a little help new to the voyager bike.
thanks
water leakng
- debron
Re: water leakng
Have you pulled the reservoir bottle out to see if the leak is coming from where the hoses connect? It can be pretty stubborn to pull out but just give it a tug. There is only one screw holding it in and it's obvious.
- Current bike(s): 2003 kaw voyager 1200
Re: water leakng
well i got it off this morning looks like the ring that holds the hose on leading to the radiator was not doing it's job, part way sliped off. hope that is it..mikey wrote:no but as soon i can get back out there i'll give it a try..thanks
